Old 07-12-2010, 07:06 AM
Default Aftermarket stock style spindle?
Most everything I've read, with the exception of marketing material , says that the drop spindles are bad news. However, it seems there are tons of companies making and marketing them. Trusting the forums I'm going to stick with a stock style given my current build plan. I'm going to need a new set of disc spindles though. Is there one set that is better than another? I'm guessing most are imported.
Current plan:
Stock subframe clean, weld, etc
G-mod
Speedtech UCA/LCA
QA1 DA coilover setup
Thanks,
John
John
'71 Nova (Build thread)
FFR Roadster
Old 07-12-2010, 08:41 AM
Musclerodz's Avatar
Short ATS spindles is what I would run. And the cost savings on the brakes would pay for a bunch of the spindle price.
Mike Redpath
Musclerodz & Customz
facebook page
Old 07-12-2010, 01:11 PM
FreddieCougar's Avatar
FreddieCougar FreddieCougar is offline
Just to clarify what Mike is saying..."short" means stock height, not dropped or shorter than stock. We call them short to differentiate them from the "tall" spindles.
Tim
Tim McCain
[email protected]
instagram - timdrawscars
Old 07-12-2010, 03:16 PM
Apogee Apogee is offline
If you want to stick with the stock type spindles versus something like the AFX option, I would find a clean pair of original, take-off spindles myself. Disc or drum, they're still going to be better quality than what I've seen from the imported ones in the past and you should be able to get brake kits to suit your needs either way if upgrades are in your plans.
Tobin
KORE3
www.kore3.com
Old 07-12-2010, 03:29 PM
Musclerodz's Avatar
Tim
Also since he is planning to do the g-mod, tall spindles won;t work.
Mike Redpath
facebook page
Old 07-12-2010, 03:58 PM
MODO Innovations's Avatar
If you haven't done the G-mod yet, I would save the time by not doing it and buy the ATS tall spindles.
Shannon
Modo Innovations
940-391-9002
Old 07-12-2010, 05:28 PM
Some more info...
I already have a set of Wilwood 4 piston front brakes. Nothing fancy but something I picked up when plans were more focused on drag strip . Regardless I want to still be able to slap on some 15" wheels so I think I'm stuck with small brakes anyway. I think this also precludes me from using the ATS spindles tall or short.
Hearing that OEM spindles are stronger than the aftermarket ones is not what I wanted to hear but certainly something I thought was a real possibility. That's a bummer. That's also why I asked here before just ordering up a set from random manufacturer.
Thanks,
John
John
FFR Roadster
Old 07-13-2010, 04:26 PM
Blake Foster's Avatar
ssbc has a brake kit available for the ATS spindle that will fit "Most" 15 " wheels we are currently workingto see if we can sell them. but you can always check them them out on line
Blake Foster
www.speedtechperformance.com
