04-20-2009, 09:05 AM
The Novice's guide to mini-tubbing a 68-69 Camaro
04-20-2009, 09:06 AM
6. Next find the welds on the inside of the trunk that hold the deck lid braces to the inner tubs:
One thing that wasn't clear is, you need to resuse the deck lid braces. Make sure you are easy on them or you are going to need to fabricate new ones (DSE doesn't give you templates for this).
7. Now drill out the welds. For the ones holding to the inner tubs it is probably easier from the outside to do but inside might be easier to make sure you can resuse the braces.
I drilled them out from inside where I could then finished by drilling outside:[
Drill out the rear seat braces as well where it is held in place inside:
8. Follow the DSE instructions on drawing the lines you need. One thing that wasn't clear was how to get the radius at the end properly. What I did was take some paper and scribe the mini-tubs outline on the paper then take the paper and using it as a guide to scribe the same outline lining up with the lines I had already drawn:
I used to a scribe to draw all my lines.
9. Next is actually cutting out the inner tub. I cut just inside of the seam as my first cut:
Now you want to cut as close as you can to the inner tub so you can remove it cleanly. That will allow you make the additional cuts you need to make enough room for the new tubs:
Plan on being in the trunk a lot for cutting, grinding and welding:
Once you have the tubs out it should look something like this:
04-20-2009, 09:08 AM
14. Now fabricate your close outs. This is where the plasma cutter or even a band saw with a metal cutting blade will really pay off. If none are available use your cut-off wheel. I drilled and counter sunk the holes for spot welding:
I also used a cutting torch (oxy acetylene) to heat up and bend the close outs to the proper radius to fit my open frame rails. It is much easier to bend 1/8" steel when it is red hot.
15. Now mock up the closeouts. This where the C-Clamps and Bar clamps come in really useful:
Grind flush as necessary.
04-20-2009, 09:20 AM
Your post helped me out a lot, the video was kinda moving too quickly. I looked over the instructions and your post a few times and just started cutting one side is done so far. I will post some pictures up this week. Thanks for the great photos.
Jason
