Old 04-18-2016, 09:02 AM
cpd004's Avatar
cpd004 cpd004 is offline
Default Ridetech control arms, should this move?
On the upper control arms, all 4 of these move very easily and freely around. Should they and what is their purpose?
I'm referring to the inner small washer seen in the above pic.
1971 Firebird
2017 SS
Old 04-20-2016, 06:30 AM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Have you tightened down the cross shaft nuts all of the way? I can't really tell in the picture you posted but the washers will be loose until those nuts are tight.
Old 04-20-2016, 06:45 AM
cpd004's Avatar
I'll have to double check that. I thought I tightened them up tight, but not too tight so that there would be bind. I just may have them a little too loose.
1971 Firebird
2017 SS
Old 04-20-2016, 07:37 AM
cpd004's Avatar
Here's another pic I uploaded a while back. I'm suspecting the arms are too loose.
1971 Firebird
2017 SS
Old 04-20-2016, 12:18 PM
No torque spec given but:
5. Tighten cross shaft nuts enough to create a drag on the delrin bushings, the arm should still move.
What I am seeing is tighten the nut @ ride height till the slack is taken up on the washer. 1/4 turn past. Retest.
Old 04-20-2016, 12:48 PM
cpd004's Avatar
Thanks Vince. In my #5, the instructions aren't worded like that. All I have is 'Position the suspension at mid travel and tighten the cross shaft nuts.'
I was so worried about bind, I did not tighten these enough. All 4 inner washers move freely and easily quite a bit. This is hopefully the source of the loose clunky feeling I have. I'll have to double check the rear as well.
1971 Firebird
2017 SS
Old 04-20-2016, 12:54 PM
Strange!! Be nice to have an actual torque number too. We like a reachable goal.
Also remember that the front support weight is 500 + LBS and don't go by what you can lift or push down on when gauging actual bind.
That clunky feeling you are experiencing maybe the harshness from the heims in the coil over mounts. There is very little give in them as rubber has.
Old 04-20-2016, 01:08 PM
cpd004's Avatar
They appear to be rubber on mine if I'm not mistaken. Wonder if that would make a difference in how tight it should be.
1971 Firebird
2017 SS
Old 04-20-2016, 01:13 PM
sorry, I meant on the coil over mounts. Top is usually delrin and the bottom is a metal heim ball.
Old 04-20-2016, 01:29 PM
cpd004's Avatar
Got ya. Thanks so much for the help! This is definitely new territory for me. I'm the guy they should hand the whole kit too while someone watches and writes instructions. A video wouldn't hurt either.
On another note, is it possible to overtighten the lower bolt that goes through the two spacers at the heim ball? I would guess it wouldn't matter as this shouldn't prevent the ball from moving freely.
1971 Firebird
2017 SS
