Old 03-28-2011, 09:52 PM
6carmello8 6carmello8 is offline
Default Painted or powerdercoat bumpers ?
Whats recommended and does anyone have any pictures of either or?
Thanks.
Old 03-29-2011, 06:35 AM
elitecustombody's Avatar
Powdercoated finish will be more chip resistant.
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 03-29-2011, 02:54 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Powder coating can chip too, although it is more durable. I know several of us on here, myself included, have wheels that are powder coated and have chips in the powder coat.
Because powder coating can also chip, you might want to take into account which is easier to fix. If you're worried about chips you can always put a clear bra wrap on the bumper.
Matt
Old 03-29-2011, 11:28 PM
Matt
Bra wrap sounds like a good idea. I'm probably gonna use it for the front end of the car too.
Old 03-30-2011, 10:51 AM
drednot's Avatar
drednot drednot is offline
Matt
I agree on the fixing thing. I have a harley that i have blacked out with powder coat. It has chips and scratches all over. Only way to fix it is have it blasted and re-powder coated. I want my bumpers black, so i have thought about using some tuff chassis epoxy that will be easier to touch up because it will chip no matter what you use.
Old 03-30-2011, 11:02 AM
The WidowMaker's Avatar
spi is now shipping their black epoxy with added uv protection. it seems this has been the downside to epoxy since it will turn "chalky". it may be a good solution.
i also had this decision to make, but since i cant get a powdercoater to match my color i have to do it in paint.
"The WidowMaker"
Old 04-07-2011, 07:36 AM
g356gear's Avatar
g356gear g356gear is offline
I did mine in powdercoat and then paint. Welded in the bumper mounts and shaved the bolt heads. Came out perfect.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
