Old 01-30-2006, 08:46 PM
bosstyrac bosstyrac is offline
Default 18/20 wheel & tire combo
i got a 69 camaro planning on lowering it what size tire's with 18/20 combo probably a 18x7 front wheel and a 20x8.5 or 20x9 rear wheel
post info and picture's
Old 01-31-2006, 06:10 AM
TravisB TravisB is offline
they will fit....do you plan on minitubbing???
Kenny Davis Hot Rods
Old 01-31-2006, 07:40 AM
fletcherscustoms fletcherscustoms is offline
I am curious to get in on this also. My car is mini tubbed and I am looking for 20/18 options as well.
Old 01-31-2006, 08:41 AM
markss28 markss28 is offline
If your car is already minitubbed then you should try to fit a 20x12 in the back.
Check www.introwheels.com and look at there muscle car gallery. There is a 69
with 18s front and 20 back that look killer.
how much tubbing does your car have? (like in inches)
Never Stay Stock
Old 01-31-2006, 09:04 AM
I believe a 20x12 would fit but not sure if the car would go as low as it would with a 20x10 because of the factory outer wheel house....I may be wrong though.
Old 01-31-2006, 10:18 AM
I considered 20x12, but I think tire height woudl be liek 29" which would cause problems on car with 3" drop springs. I think 18x12 will be where I go with this car or maybe a 19x13 if I can find the right tire
My car has the DSE kit in it
Old 01-31-2006, 10:56 AM
Will above work?
Old 02-08-2006, 11:52 PM
rocketman's Avatar
the new zo6 has a 325/35/19 might give it a look or 335/30/18.
