Old 07-24-2011, 10:01 AM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Default 70 GTO with 2002 z-28 brakes f/r, 1 inch vette, master cylinder...
Standard booster.
What proportioning valve (the disk drum is on it) should I run, or should I run a line pressure valve on the rear line, a proportioning valve...
OR WHAT!? Help is needed.
Jim
Old 07-24-2011, 04:32 PM
Ummgawa's Avatar
Oh c'mon, somebody else has got to be wondering the same as I. Lil help gents!
Jim
Old 07-24-2011, 05:23 PM
dhutton dhutton is offline
I have a similar setup and run a Wilwood adjustable prop valve. I don't think a residual pressure valve is needed with discs, only drums.
Old 07-24-2011, 05:31 PM
bmiller's Avatar
bmiller bmiller is offline
Originally Posted by dhutton View Post
I have a similar setup and run a Wilwood adjutsable prop valve. I don't think a residual pressure valve is needed with discs, only drums.
x2
I also changed the rear line from 1/4 to 3/16 but I don't know if thats a must for everyones apps
Old 07-24-2011, 06:15 PM
Ummgawa's Avatar
Don,
do you run the wilwood valve instead of the factory prop valve?
Thanks a million for the response.
Jim
Old 07-25-2011, 04:20 AM
Don,
Yes, just the Wilwood valve, no factory prop valve.
