Old 01-30-2017, 06:53 PM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
Default those with DSE subframe... please come in
Ok I bought one and installed it in my 69 Bird and started looking at my AC mounting...
I had the Fbody bracket on it before now dont think that will work
what have Y'all done to mount your AC comp?
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
Old 01-30-2017, 07:33 PM
dhutton dhutton is offline
Kwik Performance and Holley both have passenger side high mount AC brackets for Sanden compressors that work with F body accessories.
Old 01-31-2017, 03:00 AM
Tim john--- Tim john--- is offline
I have the Holley cast aluminum mount on my 69 Firebird and am impressed and pleased with it. I have Vintage Air Sure Fit kit and the Holley mount worked very well. The paperwork reccomended a certain length belt but I found that a belt 3/4" shorter fit better. My engine is a 2004 GTO LS1 with original pulleys.
Tim john---
Old 01-31-2017, 04:24 PM
ZMAN1969's Avatar
thanks Don and Tim
I was looking at work today and found the dreaded answer Fbody comp mount will not work, I did see Holley and Kwik and dirty dingo I kind of like the Holley stuff so far - any pics of that bracket and comp installed?
BTW on a weird side not LAT-G is blocked at work and the other PT board isnt but I really dont like the setup they have for threads
Out with the old
And In with the New!
LS6 6speed
1999 Firehawk
Old 01-31-2017, 04:37 PM
sleepertime's Avatar
sleepertime sleepertime is offline
Smile Down low...
I'm not sure that it will work with your setup but it fits much tighter than the factory mount.
I used the Allen Grove low mount for my Camaro. I am using the TCI subframe, I am very happy with results. Nice and tight.
http://www.alangrovecomponents.com/LS.htm
My build BRNAGN 1969 camaro SS
Old 01-31-2017, 08:11 PM
ZMAN1969's Avatar
Thanks Sleepertime and I like the design but when I looked at a TCI frame compared to the DSE I dont see anyway a low mount will work, please anyone else been here done this?
LS6 6speed
1999 Firehawk
Old 02-01-2017, 05:06 AM
Kwik makes a low mount bracket for the small Sanden compressor but it is for LSA/Corvette accessories. For F body accessories your only option is the Alan Grove bracket but it won't fit the DSE sub. The Art Morrison sub is the only one I am aware of that will accommodate the stock F body compressor or the Alan Grove F body mount.
Rich, I put the Holley bracket in my wife's 69 vert if you want to take a look at one installed. It is the Corvette spacing version.
Old 02-01-2017, 07:42 AM
randy randy is offline
I noticed you are in dallas. Im in allen so if you want to swing by and look at mine you can. DSE everything with a ls. Text me 972-814-8824
