Old 02-29-2012, 05:18 PM
John510's Avatar
John510 John510 is offline
Default Rear 9" assembly help
Fab 9 rear with Moser axles (big ford ends)
First time putting one together sorry for the dumb questions.
Should my axle bearings be sticking out 1/8"?
Once the axles are in Im assuming the c-clips bolt to the housing to hold the axles in right? What holds the brakes on?
[SIGPIC][/SIGPIC]
Old 02-29-2012, 05:20 PM
youthpastor's Avatar
Yep that is correct about an 1/8. What brakes do you have? Normally Baer brakes and others use the axle retainer as the backing plate, you ditch the 4 hole retainer and use the backing plate- hope that helps John
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
Old 02-29-2012, 05:23 PM
John510's Avatar
I have Baer 6S for the rear. Ill open that box today and see if there is instructions.
[SIGPIC][/SIGPIC]
Old 02-29-2012, 06:20 PM
Ron in SoCal's Avatar
John - PM me and I'll get you there...
Ron in SoCal
69 Camaro in progress
Old 02-29-2012, 09:35 PM
John510's Avatar
Hey guys do I need the 1/2" or the 3/8" T-bolts for my housing ends?
Was trying to order some but not sure which size I need. Thanks for the help.
[SIGPIC][/SIGPIC]
Old 02-29-2012, 09:42 PM
PM sent...
Ron in SoCal
Old 03-01-2012, 08:13 AM
Blake Foster's Avatar
Normally Bare brakes use a socket head cap screw to mount the bearing retainer, not the T bolts. with this you will most likley have to clearance the housing end for the bolt head. be cautious not to grind to far and break through the housing end.
Blake Foster
www.speedtechperformance.com
Old 03-01-2012, 09:08 AM
Bryce Bryce is offline
I think the FAB9 housing has tapped housing ends. At least mine does.
Old 03-01-2012, 11:39 AM
John510's Avatar
I finally found my instruction manual. It says to use the 3/8" original T bolts. Time to order some today so I can finish assembly.
[SIGPIC][/SIGPIC]
Old 03-02-2012, 08:44 AM
lol When in doubt................. Read the directions
Blake Foster
