Old 04-21-2012, 03:20 PM
aany001's Avatar
aany001 aany001 is offline
Default Help with rhino liner
I was wondering how to prep my floors for Rhino liner. I was going to sand my new floors to bare metal then hit it with epoxy primer and hit it with the rhino liner. Do I have to take it to bare metal/ Do I have to epoxy prime it? Can I just scuff my new floors (has that black coating on them) then rhino them? What other stuff u guys using open for other methods. Will be a driver and want durability.Thanks in advance.
Steve
Old 04-21-2012, 05:48 PM
dhutton dhutton is offline
I would not remove the e-coating. Bare metal should be primed.
Old 04-21-2012, 06:13 PM
John510's Avatar
John510 John510 is offline
Clean it up, Scuff it, then spray it.
[SIGPIC][/SIGPIC]
Old 04-21-2012, 07:50 PM
The WidowMaker's Avatar
just sprayed 2 truck beds with upol raptor. scuffed and shot both. the stuff is tough as nails.
"The WidowMaker"
Old 04-21-2012, 08:56 PM
badmatt's Avatar
badmatt badmatt is offline
X2 and looks great! Did it on my previous DD. I had some surface rust so I blasted from the body line down, hit it with a good etching primer than sprayed took all winter up here (-40C +all the salt) with no issues. Ill be doing it to my new DD when i get around to replacing the cab corners. And the whole underside , fire wall, back of the cab and front of the bed on NERA.
Matt
Old 05-21-2012, 09:32 AM
geberhard's Avatar
geberhard geberhard is offline
X2 that is what i do.
