Old 08-11-2012, 10:41 PM
Sieg's Avatar
Sieg Sieg is offline
Default SBC Gen 1 headers
I may need a set of headers in the near future. From my research it appears Dynatech's are the best fit, quality, and value for ceramic coated headers.
Should I be considering others?
Is the collector with ball & socket flange desirable?
My car has a 350, stock subframe, Saginaw fat steering box, manual, no a/c, AFR heads, 2.5" exhaust.
Existing header is relieved at the steering box to gain 1/16" of clearance which works due to solid motor mounts.
Thanks!
Old 08-12-2012, 05:44 AM
Track Junky's Avatar
I like the Hooker Super Comp's. With your set up you could probably get away with 1 5/8" primaries but I would get the 1 3/4".
Gaetano Cosentino
Old 08-12-2012, 08:33 AM
sik68's Avatar
sik68 sik68 is offline
Dougs D368 headers fit my car really well, clearing the pitman arm and power steering box and werent too expensive. That's the 1-3/4 part number...the 1-5/8 header may fit even better.
Steven
1968 Camaro: "TRACKDAY"
Build In Progress: https://lateral-g.net/forums/showthread.php4?t=10706
Old 08-12-2012, 12:13 PM
Hooker Super Comps really aren't the best fitting and they hang lower than most other headers it seems. Gaetano -- whatchu talkin bout Willis?
I know Mike P (mdprovee) just switched from Super Comps to Dynatechs on his 1st gen due to clearance issues with the Tru Turn install and he gained the needed clearance there FWIW.
Old 08-12-2012, 01:07 PM
If there was a smiley shruggin' his shoulder's I'd use it. What can I say, for the money I like them
Gaetano Cosentino
Old 08-12-2012, 03:42 PM
intocarss's Avatar
My Camaro has Hookers and the drivers side one hangs down in no mans land That is the only gripe i got
Old 08-12-2012, 09:08 PM
makoshark makoshark is offline
Start here...
https://lateral-g.net/forums/show...=35882&page=10
...and read through my ongoing saga of fitment issues with Dynatech headers. I can show you more reference that they are incorrectly built. They should have been built with another 1/4" clearance at the #5 primary tube. The company claims that 18" from head to head is the correct measurement for the stock motor. My research and own findings prove the actual measurement is 18 1/4" for a stock motor. Motors with aftermarket heads, such as mine, yield even more clearance issues. As of right now, the company has expressed no interest in fixing or even admitting they have a problem with their headers. They also will not allow me to speak with the engineer there again that built the headers originally.
Old 08-12-2012, 10:43 PM
Sieg's Avatar
What model number are headers you have?
Fitment issues like that are no fun, regretefully I'm finding these old cars vary quite a bit dimensionally. I'm surprised no manufacturer hasn't came out with a model that utilizes oval or rectangular tubes in that area.
Old 08-12-2012, 11:06 PM
I have the 310 part # headers, which are supposed to fit the DSE steering box. You may not have any fit issues with them in your application though. They are an extremely nice and heavy duty header, they just don't fit as advertised in my application.
Old 08-12-2012, 11:12 PM
Rod P's Avatar
Rod P Rod P is offline
is there a reason you want Long Tube Headers?
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
