Old 10-08-2013, 08:35 AM
RBuhr69's Avatar
RBuhr69 RBuhr69 is offline
Default Camber / Gauge location
I have one of the Longacre Camber gauges from my racing days but it has the magnet end version that would normally stick to a steel hub....Well I have Wilwood aluminum hubs so the magnet will not work obviously......
So I was searching and saw someone placing the gauge actually on the Rotor. So is this an acceptable location to place it on through the wheel to get a reading or would that be an inaccurate reading versus in/on the actual spindle end itself?
Thoughts?
Old 10-08-2013, 08:39 AM
Yes, it's square to the hub.
You can also make an adapter the pushes on to your lug nuts.
Old 10-08-2013, 08:47 AM
RBuhr69's Avatar
Awesome, I didnt think it would matter but wanted another opinion.
for an adapter I was thinking of getting a seperate hub bearing cover and use it as an modified adapter to the gauge itself.
thanks!
Old 10-08-2013, 02:48 PM
DRJDVM's '69's Avatar
I have one and they make an adapter that you can screw onto the threaded spindle hub.)... The issue I've had is with the castle nut and cotter pin, there isn't much thread exposed to engage
Old 10-08-2013, 03:43 PM
RBuhr69's Avatar
ok, thanks..I will have to check and see how much thread is there and order one if it will work out. If not, I have plenty of room to put it on the rotor through the wheel openings..
Old 10-09-2013, 11:44 AM
ccracin's Avatar
ccracin ccracin is offline
thanks!
Bingo, that's what I did. I bought an extra cap and made this. You have to be careful as this thing uses a shoulder bolt and wave washer to maintain alignment while allowing you to rotate the gauge. I had to make some shims for it to work, but it does work great.
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 10-09-2013, 04:10 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
How would one use that gage on a late model AFX spindle that uses the cartridge style bearing/hub packs? I have an opportunity to buy one of those Longacre gages but I don't know if I can use it.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 10-09-2013, 05:02 PM
RBuhr69's Avatar
Thanks CCRacin, that is exactly what I was thinking
Old 10-11-2013, 12:26 PM
Ellis Ellis is offline
Default Ellis
Have 69 Chevelle Running 20x 10 wheels on rear with 275/35/19 NT-555 tires
and 19x8 wheels in front with 245/35/19 NT-555 tires, tires are low profile
gives hard ride any suggestions on improving ride. Thanks
Old 10-11-2013, 08:39 PM
David Pozzi's Avatar
I attach to the rotor when I can. I also made some thick washers that fit into the wheel center cap groove. The magnetic gage sticks to it.
http://www.PozziRacing.com
