Old 02-18-2014, 12:58 PM
Code510's Avatar
Code510 Code510 is offline
Default NEW Dakota Digital Gauges with black face, white lighting and red needles!
Dakota Digital has been offering their VHX gauges with either a Silver Alloy or Black Carbon face with Red or Blue lighting.
However for those looking for a more 'stock' look, they now offer a Black Alloy face with white lighting and red needles.
These are BRAND new. They have officially been released, but they are still building them. We have the full line up on our site, check them out here:
http://www.code510.com/brands/dakota-digital.html
We have been taking orders for them, just be aware of a build time for them.
www.code510.com
Old 02-19-2014, 10:46 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
about time I have been waiting for these for a few years. I ask them about this at SEMA 2 years ago.
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 02-26-2014, 03:22 PM
Code510's Avatar
We've had lots of requests too.
They are available for purchase on our site...but there will be the build time until they build up stock and we can get some on our shelves.
www.code510.com
Old 02-26-2014, 03:39 PM
SSLance's Avatar
SSLance SSLance is offline
Wow, those look great! I wonder if Dakota would retro-fit the black backing and red needle colors on one of the gray with blue needle units shipped out last year?
Love my gauges but those would make them look even sweeter.
Lance
Old 02-27-2014, 06:14 AM
samckitt's Avatar
samckitt samckitt is offline
I'd like to see a pic of these for a Monte. Does anyone know if these gauges will work with the LS oil pressure & water temp sensor output? Currently I have 2 of each.
Scot
86 Monte SS
LS2/T56 Magnum
Old 02-27-2014, 07:48 AM
SSLance's Avatar
They come with new OP and WT sensors that you put in place of the existing sensors (with several adapters to let them fit into different bungs). The included wire harnesses have plugs that work with the sensors as well. Those and the VSS harness were the only new wires to sensors that are needed to make everything on the new gauges functional. I pulled everything else from the 16 pin dash connector from the existing factory dash harness.
Lance
Old 02-27-2014, 10:59 AM
dontlifttoshift's Avatar
With an LS motor you can use the obdII bin module and gauge function runs off the ecm. No extra senders needed other than fuel.
Donny
Old 02-27-2014, 03:25 PM
Code510's Avatar
What's your question? You want a set with the silver/gray background and blue lighting?
www.code510.com
Old 02-27-2014, 04:09 PM
SSLance's Avatar
No, I already have a set with the gray background, blue needles and lights that I purchased last year...
I really like the black background, white lights and red needles they are coming out with now though...would consider changing to them if not too cost prohibitive.
Lance
Old 03-03-2014, 01:46 PM
ord27's Avatar
ord27 ord27 is offline
looks sharp.
question
do yall do any custom work on gauges? or know anyone?
a 1970 Superbee project.
I want to stay with the stock dash, but upgrade the gauges to a more modern type, but still have a nostalgic look.
specifically.....the tictoctach. I want it to match the appearance of the other gauges.
Perhaps a vhx/analog (?) speedo, but I'd like to have the hidden radar detector warning lights installed in the face of the speedo.
are things like that possible?
'71 'Cuda 440 6-pack, Shaker, custom A/C, 4 speed
'67 Camaro RS
newly aquired 1970 Superbee, N96 car!
