Old 04-26-2014, 12:16 PM
kholubar kholubar is offline
Default 325 or 305 for 11 inch wide wheel?
Hello,
I am trying to decide if I should go with a 325-30-20 or 305-30-20 for an 11 inch wide wheel. They are going on a 69 camaro with dse mini tubes. I am just worried that the side wall my bulge out to much with the 325. If anyone has ran a 325 on an 11 inch wheel and has pictures please post them. Thanks.
Old 04-26-2014, 12:35 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
Originally Posted by kholubar View Post
Hello,
Jackass had DSE tubs, and 20 x 12. http://www.camaroperformers.com/feat...g-1969-camaro/ (I am not sure if they did any other modifications to the wheelwell.)
Old 05-05-2014, 06:36 PM
Buick Grand National Guy Buick Grand National Guy is offline
Best to check with tire manufacturer for their recommendation!
Conrad
Original owner of 1974 Z28. Ordered car with 4 speed, LT, Air Conditioning. Numbers matching car. Now equipped with Edelbrock Pro Flow fuel injection, 96 Zette Wheels, B-Car front disk, WS6 rear disk.
Also original owner of much-modified 1984 Grand National. Ridetech front & Detroit Speed rear control arms/sway bars Ridetech 3-way coil overs. Champion aluminum heads & intake. Comp roller hydraulic cam. CF hood, fiberglass bumpers. Baer 6P (2-piece rotors) 14" front & 13" rear brakes.
Old 05-23-2014, 07:03 AM
Formula43 Wheel's Avatar
Formula43 Wheel Formula43 Wheel is offline
The 325 was designed for the C6 Z06 Corvette to be fitted on a 12.0" wide wheel. Check the specifications of the tread width and match the tread width to the wheel width for optimum performance.
Old 05-23-2014, 07:06 AM
Track Junky's Avatar
All your tire fitments go by measured rim width. For example an advertised 9.5" rim width could be 10 1/4" wide. ChecK with your tire manufacturer.
Gaetano Cosentino
Old 05-23-2014, 08:03 AM
CamaroMike's Avatar
CamaroMike CamaroMike is offline
I ran a 315/35/17 on a 11inch wide wheel, was pretty flat (no bulge or stretch)
Here they are on the front of my 2nd gen, had to do some mods to get a 315 to work up front lol
Alabama
1969 Camaro
1978 Camaro
Old 05-24-2014, 07:21 PM
Thanks everyone for the info. I ended up getting the 305's and they look good.
Old 06-09-2014, 07:03 PM
taxidermy man's Avatar
taxidermy man taxidermy man is offline
So if you order a 9 1/4" wide wheel they can send you a 10 1/4" wheel (measured at the same place) and that's ok? Never heard of such a thing.
Old 06-10-2014, 06:40 AM
Good choice!
Old 06-10-2014, 07:12 AM
You sound alot like me. I dont believe anything until I try it my self. If you dont plan on buying wheels anytime soon give one of the wheel manufacturers a call.
Gaetano Cosentino
