Old 02-08-2015, 02:53 PM
Errnie-ZL1 Errnie-ZL1 is offline
Default F2-procharger can you use VA
Hi Guys I am building a 1967 CAMARO RS with a 496 stroker with a F2 procharger. The crank only has 1 V pulley behind the cog belt.i have a brand new vintage air kit but how can I run the A/C along with the power steering and alt ? Has anyone done this ???
Old 02-08-2015, 07:28 PM
ironworks's Avatar
It's gonna be pretty tough with a vintage air front runner. Those blower drives usually have to be custom built to run an the street with all the accessories. Been there a few times.
Old 02-08-2015, 07:47 PM
Default Procharger
That's what I figured it is a side mount. Running hydra boost brackets now so unless I custom something off the crank guess I will not be able to use it.
I own a machine shop so pulled are no problem. But think it is R80 air lol
Old 02-08-2015, 08:51 PM
ironworks's Avatar
Will an f2 even fit under the hood of a 67 Camaro with out hit the hood and the inside of the drivers tire?
Old 02-11-2015, 01:17 PM
Default Procharger
Had to go with a 4" cowl hood
Old 02-12-2015, 06:54 PM
Jones made a custom set of brackets for me. One off the water pump, and one off the crank. Not exactly what you need, but it may give you some ideas.
