Old 04-10-2015, 12:44 AM
hiwayman hiwayman is offline
Default 10mm door gap
I have a door gap 10mm at the bottom of the door to the rocker this is after installing new quarters , is there a go to method to fix, welding a 6mm rod to the door? or sum other thanks Darrin
Old 04-10-2015, 09:35 AM
mitch_04 mitch_04 is offline
A lot of people weld TIG rod onto the edge, then grind until it matches the curve.
