Old 09-19-2013, 03:47 AM
Sieg's Avatar
Sieg Sieg is offline
Default CPP C5 Spindle - Camaro / Nova
Does anyone have any knowledge or experience with CPP's cast iron C5 spindles?
Affordable & attractive cast spindle.
Stock height.
Raised upper ball joint mount tall spindle to yield a better camber change during suspension movement (CP30013).
Utilize factory or CPP replacement steering arms (CP30013).
Work with factory control arms, CPP Totally Tubular™ and other after market arms.
The spindle alone works with factory 1997-2004 C5 corvette hub bearing pack, rotors and calipers.
Works with Baer, Wilwood and other aftermarket brakes designed to fit C5 spindles.
Old 09-19-2013, 04:59 AM
Z06vette's Avatar
Z06vette Z06vette is offline
I just bought a set for a project car to try them out on. Will be a while before I get to actually drive the car though. Should have them assembled in a month or so when I assemble the subframe.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 09-19-2013, 08:28 AM
Sieg's Avatar
For those on a budget they look very tempting if the quality/safety is there.
Are you using their C5 hub kit also?
Thanks for the input.
Old 09-19-2013, 10:17 AM
dhutton dhutton is offline
There was a lively exchange between Tyler and the designer of the CPP spindle over on the other PT site if I remember right...
Edit: http://www.pro-touring.com/threads/9...cpp+spindle+c5
Old 09-19-2013, 11:05 AM
Blake Foster's Avatar
There is one word in that statement............
Blake Foster
www.speedtechperformance.com
Old 09-19-2013, 11:39 AM
Sieg's Avatar
Old 09-20-2013, 03:10 PM
Z06vette's Avatar
Ya, budget, i know. MCB was having a garage sale on open box stuff. The price was right, I already have C5 brakes & front hubs (used low mile off C5). I figured I'd try this stuff out. The car wont ever be used on an open track. I'll eventually sell it, but will drive it a while first. Should be fine for street use & autocross. I enjoy building first gens, trying different things with them (other than they all will have LSx engines) and learning a little in the process.
69 RS LS3/T56
67 RS LS2/T56
Old 09-23-2013, 09:00 AM
The word I was referring to is "IF"
Blake Foster
Old 09-23-2013, 09:17 AM
Sieg's Avatar
That was my assumption Blakester.
Old 09-28-2013, 08:50 AM
tigerchevelle tigerchevelle is offline
I dont know the quality of the material the cpp spindles are made from,but if youve seen a 71-72 c10 disc spindle its cast iron and there a few guys tracking on that type of spindle,i think mike hickman's 68 is using cast spindles maybe he can chime in if hes on the forum,he is an engineer.
