Old 03-01-2017, 02:55 PM
Hurst_Drivelines's Avatar
Hurst_Drivelines Hurst_Drivelines is offline
Default Hurst Driveline Conversions Crossmember Kits for 64-66 Mustang w/AOD or Tremec T5
If you plan on installing an AOD automatic or Tremec T5 manual transmission into your 1964-1966 Ford Mustang, Hurst Driveline Conversions now offers bolt-in solutions that will simplify your conversion.
Part # 67530002
Hurst Driveline Conversions Crossmember Kit for the 1964-1966 Ford Mustang with an AOD automatic transmission
Description:
This custom built bolt-in crossmember kit is specifically designed for properly installing a Ford AOD automatic transmission in all 1964-1966 Mustangs. This crossmember also features a provision to retain the factory parking brake function. Manufactured in the USA from heavy gauge steel and has a black powder coated finish for long lasting durability. Kit includes crossmember and mounting hardware.
Part # 67530003
Hurst Driveline Conversions Crossmember Kit for the 1964-1966 Ford Mustang with a Tremec T5 manual transmission
Description:
This is a custom built bolt-in crossmember kit and is specifically designed for properly installing a Tremec T5 manual transmission in all 1964-1966 Ford Mustangs. The crossmember also features a provision to retain the factory parking brake function. Manufactured in the USA from heavy gauge steel and has a black powder coated finish for long lasting durability. Kit includes crossmember and mounting hardware.
Please call 707-544-4761 or visit www.Hurst-Drivelines.com for additional application and product information.
