Old 03-07-2016, 08:06 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Default MillerBuilt's WELD-ON C6/7 Hybrid Floater System
C6/C7 Hybrid Floater System -
These NEW billet steel Adaptors Weld-On to nearly any axle tube!
Advantages:
  • Welds to your new OR existing housing
  • Reduces/eliminates brake “knockback”
  • Eliminates axle deflection
  • Wheel & tire remains intact should an axle failure occur
  • Front or Rear Caliper / E-Brake Cable Positions
  • Utilizes the robust, zero maintenance C6/C7 ZO6 Hub Bearing Unit
  • Utilizes OEM C5/C6/C7 Corvette, and 5th Gen Camaro brake kits
  • Utilizes aftermarket C5/C6/C7 Corvette, and 5th Gen Camaro brake kits
  • Utilizes your existing BAER / WILWOOD caliper & rotor (some restrictions apply)
  • Super compact design compared to traditional style full floaters
  • All advantages of a traditional style full floater without the maintenance
  • Replacement parts available at local GM dealer or local parts house
  • No modifications required to the hub bearing unit as other kits in the marketplace
Fitment: Any rear-end with 2.750”-3.250” o.d. axle tubes
See information listed below for both the "long" and "short" versions...
Weld-On “Short" Base Kit (pictured below)
Weld-On “Short" Base Kit (pictured above)
Base Kit (Short) Includes:
• (2) Billet Steel, Short Hybrid Floater Adaptors
• (2) Billet Aluminum Caliper Brackets
• (2) C7 Corvette, SKF 33 Spline Hub Assemblies
• (1) Install Kit
• (2) Hub Spacers
• (2) Billet Aluminum Hub Cap Seals
________________________________________
STARTING AT - $1,398.00
Base Kit (Long) Includes:
• (2) Billet Steel, Long Hybrid Floater Adaptors
• (1) Install Kit
• (2) Hub Spacers
STARTING AT - $1,498.00
Add Axles - $400.00
• (2) Hy-Tuf Full Float Axles
Add E-Brake items - $325.00
• (2) C5/C6 Corvette Complete E-brake Assemblies
• (2) C5/C6 Corvette Parking/E-brake Cable Brackets
Have interest?
Have questions?
Need more info?
Distributor Inquires Welcome!
To help determine which kit might work best for your particular application, please see below picture.
Questions welcomed!
Old 08-06-2016, 10:53 AM
Default FREE Shipping & PayPal This Weekend!!
FREE Shipping & PayPal This Weekend!! (8/6/16 & 8/7/16 - "lower 48" states only)
Old 10-01-2016, 02:43 PM
Default October Special!
FREE Shipping & PayPal through October!! ("lower 48" only)
Advantages:
• (1) Install Kit
• (2) Hub Spacers
• (1) Install Kit
• (2) Hub Spacers
Add Axles - $400.00
Have interest?
Have questions?
Need more info?
Questions welcomed!
Old 10-06-2016, 08:16 PM
This........ (floater ends)
Gets you to this..... (complete hybrid full floater system)
Housings can be supplied as well for a complete solution......
Thanks for looking!
Old 10-19-2016, 06:41 AM
Advantages:
• (1) Install Kit
• (2) Hub Spacers
• (1) Install Kit
• (2) Hub Spacers
Add Axles - $400.00
Have interest?
Have questions?
Need more info?
Questions welcomed!
Thanks for looking!
In Stock!
Old 02-09-2017, 06:49 PM
Advantages:
• (1) Install Kit
• (2) Hub Spacers
• (1) Install Kit
• (2) Hub Spacers
Add Axles - $400.00
Have interest?
Have questions?
Need more info?
Questions welcomed!
Thanks for looking!
In Stock!
Old 06-05-2017, 06:18 PM
Default In Stock
In Stock
