Go Back   Lateral-g Forums > Classifieds > Wanted/WTB
Old 04-08-2018, 01:49 PM
phil_L phil_L is offline
Default 1969 firebird pedal assembly
Hey guys,
I am on the hunt for a 4 speed manual pedal assembly for my 1969 Firebird....based on my research, the 69 Camaro and the 69 Firebird used a different assembly. Firebird was a bolt style. Not sure if the Camaro assembly would fit.
Thanks!
Phil
Old 04-08-2018, 05:42 PM
Tim john--- Tim john--- is offline
Phil, I responded to your thread on Pro-Touring, check there when you have a free moment or just reach out to Ron Johnson at Potomac Pontiac, he will or should have the correct pedals for you. Yes, they are a one year only and Pontiac Firebird specific.
Tim john---
The Following User Says Thank You to Tim john--- For This Useful Post:
phil_L (04-12-2018)
Old 04-08-2018, 08:27 PM
Tim john---
Thanks for the lead...now that I know for sure they are a one year specific, my next question is, does the camaro assembly fit or no? I am building a PT so no need to have a OE part if I don’t have to.
Thanks again.
Old 04-09-2018, 11:25 AM
shelteredV's Avatar
shelteredV shelteredV is offline
He said they are Firebird proprietary, and I remember the same thing when I did this a long time ago.
The Following User Says Thank You to shelteredV For This Useful Post:
phil_L (04-12-2018)
Old 04-12-2018, 08:08 PM
Tinker's Avatar
Tinker Tinker is offline
Hey Phil,
I ran into the same problem with my '69. I bought two sets of pedals from someone who had a '69 Camaro, but the bracket is different than the Firebird version. I was three days from the maiden voyage of my car and found out the brake pedal is bent in two places around the steering column for the Firebird and not the Chevy. What I did was to put the chevy clutch pedal in the Pontiac bracket with the automatic Pontiac brake pedal and trimmed the metal foot pad to fit the rubber pad of the manual pedal. The brake pedal hung lower than the clutch, so I straightened the clutch pedal in the places it is already bent in to lengthen it to match the brake pedal. Works great and nobody is the wiser.(until you broadcast it on the internet). Let me know if you need some pics.
Chris
Old 04-16-2018, 07:47 AM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
Im afraid I may be same boat I put whole pedal assy in from ?camaro? went right in but no column in car yet. can you post some pics please?
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
Old 04-18-2018, 06:02 PM
Tinker's Avatar
Default pedal pics
Here are some pics of my pedals. First pic shows how the brake pedal wraps around the column. This is the stock shape. I just trimmed the pedal portion to fit the manual pad vs. the larger automatic pad. The clutch pedal is the one I actually straightened to get the lengths to match and space between. Notice how I took the two bends mostly out of the clutch pedal as compared to the last pic. The Firebird top bracket is straight, not offset as the brackets in the bottom pic shown. The bottom pic is the one purchased from a friend who had it installed in his Camaro. I believe both brackets are actually A-body brackets and the front holes were notched to make it work in the Camaro. Anyone with an A-body looking for pedals? As far as clutch cylinder it is a late model F body clutch master that I machined an extension to the rod so I could bolt on a female rod end that bolts to the pedal arm. Sorry for the sideways pics, but now you can read my post while you are in bed.
Hope this helps.
Chris
Old 04-19-2018, 12:42 PM
ZMAN1969's Avatar
Thanks Tinker I'll look at mine next time in shop maybe the difference was A-body pedals VS F-body?
LS6 6speed
1999 Firehawk
Old 04-19-2018, 03:11 PM
Tinker's Avatar
I hope for your sake that was the difference
Chris
Old 04-20-2018, 01:26 PM
ZMAN1969's Avatar
yeah I cant see why Camaro-Firebird year for year would be any different
I know little different body wise - engine wise but its not like steering column is mounted somewhere else in the car
sorry didn't mean to hijack your thread Phil!
LS6 6speed
1999 Firehawk
