Old 05-22-2018, 05:35 PM
bergers59 bergers59 is offline
Default Need more info/dimensions on ATS Camaro spindles
Looking for some dimensions and bearing load info on the 1st gen camaro ATS spindles. I like the idea of them and they look like a great product, but for me to jump and buy them I need to know that they fit my goals rather than just "improves negative camber gain". The car they're going on is a fairly hardcore street/race car, not too many comforts, and will be total build from scratch suspension wise. I plan on analyzing my geometry using LOTUS Shark, so it would be greatly appreciated if someone could get me these distances and caster, or at least equivalent KPI and caster.
Old 05-23-2018, 06:42 AM
Blake Foster's Avatar
the kpi is 8 deg
the cl of hub to ubj is 6.81
the cl of hub to lbj is 4.02
hub face to ubj is 7.2
i do not have hub face to lbj
don't understand the caster question?
Blake Foster
www.speedtechperformance.com
Old 05-23-2018, 09:18 AM
Was going to tell you ask speedtech being as they're the manufacturer but , you got the man himself already answering everything for you , good luck
Old 05-26-2018, 09:43 AM
Originally Posted by Blake Foster View Post
the kpi is 8 deg
That's awesome I appreciate it. By caster I meant if there was any built in offset from the sideview between upper and lower balljoints, but looking at pictures of them I don't think there is.
Old 06-18-2018, 11:18 PM
I should have been more specific, but those numbers you gave me were the center of the balljoint, or the center of the hole where the balljoint bolts in?
Old 06-19-2018, 07:16 AM
ball joint center
Blake Foster
The Following User Says Thank You to Blake Foster For This Useful Post:
camcojb (06-19-2018)
Old 06-19-2018, 08:29 PM
ball joint center
Awesome, Thanks again!
