Old 04-29-2009, 05:07 PM
speedshftr speedshftr is offline
Default 68 camaro real wheelwell questions
car is curently in body shop i just cant swing the mini tubs.should i have my rear quarter lips rolled or should i trim them back some?or both?
thanks again?
Old 04-29-2009, 07:42 PM
68MaroSam's Avatar
68MaroSam 68MaroSam is offline
It all depends on the wheels and tires you plan on putting in there. My suggestion out of the two choices is to roll them. If you just trim them back, you still have the possibility of slicing your tires, if you roll. There is a better chance of survival for your tires.
Sam
'68 Camaro
'56 210 Coupe
Northern Utah
Old 04-30-2009, 05:07 AM
jy211's Avatar
jy211 jy211 is offline
just wait until the car is done. You can always roll or trim them later.
Old 04-30-2009, 06:17 AM
68MaroSam's Avatar
I have a roller from Eastwood, and did a 67 Camaro that had some bondo in and around the wheelwell. Bondo doesn't roll very well, and it fell off in several areas. So, I would use caution rolling later if painted and there is any bondo in the wheelwell area. I am sure trimming later should be ok.
Sam
'68 Camaro
'56 210 Coupe
Northern Utah
Old 04-30-2009, 11:08 AM
DriverzInc DriverzInc is offline
I would have them rolled now, can't hurt anything.
Old 04-30-2009, 02:17 PM
buickfunnycar.com's Avatar
Agreed...what's there to lose?
www.buickfunnycar.com
Old 04-30-2009, 04:04 PM
almcbri's Avatar
almcbri almcbri is offline
http://www.harborfreight.com/cpi/cta...emnumber=98793
here is one for $80
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 05-20-2009, 03:08 PM
Sharky1967's Avatar
Sharky1967 Sharky1967 is offline
Please roll them now and make sure the edge is curled away from tire. Realize that on the Camaro with leaf springs that as the rear spring moves up the rear tire moves forward and up, not just up like many would think just looking at the car. If you stuff a tall tire in there that is not all the way inside the wheelwell lip it will catch the lip at 9 o'clock position when looking at the drivers side. You would think that the lip is flat and easy to roll but it is not easy to do after the fact and it will not roll all the way up without causing some damage. I did DS minitubs and offset billet spring shackles and was still very sorry that I did not have them tucked up and rolled in to not have any edge to grab a tire. Had plenty of clearance while sitting still and moving the car through all the travel but get out into real life driving, people in back, off camber roadways and a tire grabbed an edge and $3,000 later we have learned our lesson.
1967 Camaro
Procharged and Intercooled 14# SBC 406
Gear Vendors 6 spd, A/C, 9", 4WDB
Old 05-25-2009, 04:04 PM
thanks for the input everyone/
