Old 03-14-2007, 05:58 AM
jjl4004 jjl4004 is offline
Default Where to start?
Hello all. I have finally saved up enough $ to start the conversion of my 68 Chevelle to a pro-touring car. It currently has stock front disc brakes, rear drums, stock suspension, springs and shocks. I plan on putting on some 18" wheels and of course, need the right stance. The car will remain a street car and hopefully some day will be ready for a road course (once a year or so), but what I really want is the car to look good and handle well.
My question is, where do you think I should start this project? Should I start with beefing up the suspension components with somehting like a Hotchkis TVS system? Would coil-over shocks get the car's stance right? Dropped spindles? If I go with the drop spindles, don't I need to convert the brakes at the same time, and then that would also require me to get the wheel/tire combo as well? I'm guessing wheels/tires/brakes all should be done at the same time...?
I'm just looking for a little direction from you guys since you have been in my situation before. I currently have around $2,000 to spend on the first portion of this conversion. (Credit card is available as well if I need to spend a little more )
Old 03-14-2007, 10:14 AM
T Bell T Bell is offline
what condition is your '68 in? Mainly the underside, any rust on the floors? Need motor work? I'd get it running mecahnically and then the safety issues 1st.
1972 Nova 355, 4 spd, rusty but something to drive.
1972 Pro-touring Cutlass S in the works....still
Old 03-14-2007, 10:42 AM
Bandit's Avatar
Bandit Bandit is offline
I would go with the wheel/tire package first, since that is where you are going to see your largest single handling improvement. It will also help you establish a baseline from which to measure your future upgrades. Plus it will upgrade the looks of your ride considerably, which provides motivation. Maybe do the brakes second--it is always a good idea to improve braking and add safety. The TVS is a great choice for a mostly street-driven car--it would save some work overall if you could do the new brakes at the same time. I would also be looking at getting solid aluminum body mount bushings to replace the stockers--they are inexpensive and make a difference that you can really feel. After all that, Upper control arms would help too.
This is a logical approach and the way most of the car mags have done it in articles I have read. Good luck!
1980 Pontiac Trans Am, Chevy BB 402 + .010, TKO 600, Motive 3:73's, Hotchkis TVS, Coddington Junkyard Dog 18's, Nitto NT555 rubber, Autometers
Old 03-14-2007, 02:22 PM
T Bell: The car runs great (rebuilt engine 3 years ago) and there are no mechanical issues with it. There is some rust on the floor pans, but none on the body.
Bandit: Wouldn't getting the wheels first create a problem when I get to the fine tuning of the suspension drop, rear disc break conversion and overall stance of the car? I'll have to take a look at solid aluminum body mount bushings, as I don't know too much about them.
Thanks for the responses...I value the opinions. I just got a digital camera, so I might take a couple pictures of the car and post them if I can figure it out. Anyone else think I should go a different route?
Old 03-19-2007, 05:32 AM
I pulled the cover up and took this picture last Thursday. I haven't got it out yet this year..still salt on the roads.
Old 03-19-2007, 06:40 AM
I would start with suspension and steering and / or brakes. If you are on a budget, you cannot beat a Hotchkis TVS sytem to get the stance and handling. You may want to do a quality steering box and new tie rods / centerlink if required. You could consider adding front control arms also. Then I would look at brakes.
Frank Serafine
