Old 12-29-2006, 01:57 PM
mark smith mark smith is offline
Default an fittings and teflon tape?
ive never used an fittings before.is it neccessary to use teflon tape on these connections?
Old 12-29-2006, 02:01 PM
Sales@Dutchboys's Avatar
I would.
dutchboyshotrods.com
269-823-2967
Old 12-29-2006, 02:02 PM
GBodyGMachine's Avatar
GBodyGMachine GBodyGMachine is offline
I never have. I thought they were a flare fit. Like brake lines.
Jeff
84 Regal Project GBodyGMachine
[SIGPIC][/SIGPIC]
Old 12-29-2006, 02:04 PM
XcYZ's Avatar
XcYZ XcYZ is offline
No, not needed.
My LS7 69 Camaro
Old 12-29-2006, 02:06 PM
XcYZ's Avatar
But it is a good idea to put a bit of oil on the threads when making the hose end so the threads don't gall.
My LS7 69 Camaro
Old 12-29-2006, 02:20 PM
Hmmm I thought it was a good idea too....
but I dont when we deal with brake lines.
269-823-2967
Old 12-29-2006, 02:41 PM
3kidsnotime's Avatar
3kidsnotime 3kidsnotime is offline
On a fitting the NPT side I always use a sealant on the flare or hose end side none just a lubricant to resist galling and do not over tighten
Old 12-29-2006, 05:21 PM
rwhite692's Avatar
The threads don't play a role in the sealing, the flared contact area between the two components forms the seal. The threads only provide the clamping force. No need to use teflon tape (or any sealant of any kind) on the threads. I use silver anti-sieze compound (a very very small amount) on the threads, I have never seen anything that worked as well to prevent galling of aluminum threads on AN fittings...Just my $.02 -Rob
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 12-29-2006, 06:24 PM
Silver anti-sieze is my fav as well on the 37*flare side but still a fitting has usually a npt thread such as 1/4 3/8/1/2 npt that you are threading into something fuel pump intake what have you on the npt side the threads ARE the seal and I always use something on that side. Ill post a pic later as not to confuse, now an fittings that have a seat on the other side such as brakes hydroboost some fuel logs and regulators I only use anti-sieze on them
Old 12-30-2006, 06:18 AM
Default thanks for repllies
getting ready to install my ricks tank with the pump in it.sounds like ill tape the fitting directly off the tank and anti seize the rest.thanks again.
