Old 02-14-2007, 12:43 AM
Default Any external differences between LS1 vs LS7 ??
Hello!
What are the major differences between LS1 vs LS7 , and i am only talking external differences for mock up use. I have LS1 engine and can i trial fit headers , intake , wirings , assesorys,engine mounts with it ?
I know the oilpan is different. I am planning to bay one as used to make oil lines in future.Does it bolt right on LS1 ?
63 Z06
Old 02-14-2007, 05:27 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Yep, everything else will bolt up - trans, headers, etc. The exhaust ports are different on an LS7, but LS1 headers will still bolt up.
My LS7 69 Camaro
Old 02-14-2007, 05:34 AM
Sales@Dutchboys's Avatar
Not to highjack....but what about an LS2 and an LS7?
dutchboyshotrods.com
269-823-2967
Old 02-14-2007, 05:38 AM
Thanks Scott!!! Great news , now i can do all the fabbing first and get the engine last.
63 Z06
Old 02-14-2007, 06:48 AM
XcYZ's Avatar
I'm not sure about the water pump, though. Anyone know if they are signicantly different?
EDIT: The water pumps are basically the same with a slight difference in the intake manifold area for clearancing.
My LS7 69 Camaro
Old 02-14-2007, 07:37 AM
Awsome! Then i can build cooling and everything over it
63 Z06
Old 02-14-2007, 08:36 AM
XcYZ's Avatar
What are you doing for accessory drive? That's my current research project.
My LS7 69 Camaro
Old 02-14-2007, 09:52 AM
Ilike the looks of fbody..espially after seeing Steves penny
I recall cadilla CTS (??) had nice looking too.Big question is can i use stock gm ac compressor with vintage air systmem?
EDIT: I found this system from DSE . As much as i like all DSE stuff i dont understand the value of this 3500usd system vs stock Fbody.Not even looks.
63 Z06
Old 02-15-2007, 12:35 PM
29od1 29od1 is offline
I don't believe that the stock compressor will work with Vintage Air. But they do make a bracket that adapts a Sanden compressor to the stock A/C bracket and locates it in approximately the same position.
Old 02-15-2007, 09:59 PM
That is the DSE new setup eh?
Looks pretty good, but looks like the water pump will not allow a factory manifold or throttle body to be used with it because of the T stat location.
Here is your other alternative- The Sidewinder.
Tyler
