Old 10-12-2007, 07:20 PM
mazspeed's Avatar
mazspeed mazspeed is offline
Default Here is the new supercharger hat
Ok, I have the hat now in the car. I'm hoping this should help do the trick. We are also adding a cool water injection kit, and a J&S knock sensor ignition system.
The second pic is where the tank is going to go. In the trunk.
Old 10-12-2007, 07:46 PM
thinking good thoughts for you buddy. This should make quite a difference once tuned properly.
Old 10-12-2007, 07:52 PM
mazspeed's Avatar
I'm hoping. This was on your advice too
I missed you guys at the Goodies event.
Old 10-12-2007, 10:41 PM
mdprovee's Avatar
mdprovee mdprovee is offline
Hey Mike good luck with it. I really hope it works out for you.
Jason said he was going to talk with CAR about your install so mine might go a little easier.
Keep us updated on your progress.
Mike
Old 10-13-2007, 12:12 AM
mazspeed's Avatar
Mike, get that hat. Well let me give you the results first, and then you may want to get this hat. After a bunch of research, the procharger hat is junk. Ill post changes and the dyno results and give you the info on it, since you have the same thing. I don't want you going though what I have been though. The water injection and or some kind of cooling for the air intake are going to be critical. Also we are doing a custom knock sensor that will regulate each cylinder for detonation, therefore retarding each cylinder individualy and not all of them at once which will kill power. Have J talk to Kevin about this. Give them a few weeks to have it done and have dyno results. Ill post before and after.
Old 10-13-2007, 11:12 AM
Rybar's Avatar
Rybar Rybar is offline
Mike good luck, glad you are sticking with it. Once tuned your ride will be fun as hell with the torque of the blower
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 10-13-2007, 12:02 PM
yeah, well no pressure there.............
Old 10-13-2007, 12:44 PM
mazspeed's Avatar
That's right man, it best be werken soon.
J/K
Well it better.
Old 10-15-2007, 08:46 PM
mdprovee's Avatar
Thanks Mike, but I am running a Holey Stealth Ram Fuel Injection, so no carb. Hopefully wont run into to trouble.
Let us know how it all rings out.
Mike
Old 10-15-2007, 11:07 PM
mazspeed's Avatar
Cool, it that should work better for you.
Let me know how it goes. Where are you on the progress?
