Old 07-04-2009, 06:03 PM
scottybuck 11 scottybuck 11 is offline
Default Gas Guage Wont Read.
put my narrowed tank in from dseand it only reads a quarter of a tank.whats my problem fellows?
Old 07-04-2009, 06:41 PM
JamesJ JamesJ is offline
You most likely need to give a bit more info, factory gauge? all you did was switch the tank? nothing else changed?
James J.
Old 07-04-2009, 06:47 PM
i have autometer guages.it was working fine.i minitubbed the car so i had to put in the narrowed tank and a dse sending unit.now my guage reads 1/4 of a tank when its full.
Old 07-04-2009, 07:03 PM
dhutton dhutton is offline
The new sender has to be the same resistance as the old one to read correctly. Sounds like it is not.
Old 07-04-2009, 08:05 PM
1984 camaro's Avatar
1984 camaro 1984 camaro is offline
Float could be hitting the tank. You said it worked before and you narrowed the fuel tank ? and it does not work now. thats what you should check
Old 07-04-2009, 08:35 PM
jpdeuce's Avatar
jpdeuce jpdeuce is offline
I bet the float is sticking or hitting something making unable to get full travel. I have had this happen before with both DSE and stock tanks.
