Old 03-15-2009, 10:57 AM
goob8869 goob8869 is offline
Default front backspace help
I have a 67 Camaro and bought a set of wheels that fit perfect until i put a disc conversion on it now the wheels are hitting the fenders instead of tucking under. Can someone give me the backspace for this problem. The conversion pushes the wheel out 1/8 inch.
Old 03-15-2009, 11:17 AM
awr68's Avatar
awr68 awr68 is offline
What size wheels/tires do you have right now?
Tony
'68 Camaro
Old 03-15-2009, 09:18 PM
17x8 but I am going with 19x8 on the new wheels
Old 03-15-2009, 10:48 PM
awr68's Avatar
4.75" - 5" bs is what we all use on an 8" wheel...I prefer 5" bs and a 245 tire.
I would see what your current bs is and go from there.
Tony
'68 Camaro
Old 03-16-2009, 03:16 PM
they are 4.75 with a 245 tire
Old 03-16-2009, 04:15 PM
awr68's Avatar
Does the car have a good alignment? Those should work. Is the car lowered? What suspension are you using?
Tony
'68 Camaro
Old 03-16-2009, 04:21 PM
Be careful of overall height on those 19" tires, if you make the tires to tall, they will rub.
You 4.75 should work fine. You need a alignment
Frank Serafine
Old 03-16-2009, 10:07 PM
The car is lowered and I am running QA1s with tubular a arms. What profile should I run with the 19"wheel, and should I reorder 4.75 or go with 4.87 to be on the safe side. The car does need to be aligned since I put on the a-arms. Thanks for the help
Old 03-17-2009, 01:46 AM
There is a lot to it. I will need to know what rear set up you want to run so I can find a set of tires that have the sizes, aspect, bulge we need in the same brand
Just call me. It is way easier to talk then type.
Frank Serafine
