Old 11-02-2009, 04:11 PM
speedshftr speedshftr is offline
Default battery in trunk?or engine conpartment?
not sure if i want to look at the battery every time i open the hood.where you guys putting yours at?
Old 11-02-2009, 05:59 PM
Denvervet's Avatar
Denvervet Denvervet is offline
trunk....puts more weight in the back too. So win win situation.
68 camaro, 572, tko
Old 11-02-2009, 07:11 PM
markd's Avatar
markd markd is offline
What he said ^^ Trunk!
Below is a picture of mine with a DSE battery relocation kit.
Project 69 Camaro: DSE mini tubs, Chassisworks G-Bar and FAB-9 rear suspension, Chassisworks front sub-frame, 14” Wilwood brakes with 6 piston red calipers, 18" Fesler 905 Wheels, Fesler Billet, ISIS multiplier system, Vintage Air, Prodigy Cool Package, Ricks Tank, Turnkey LS3, 4L65e transmission and a lot of other cool stuff!
More pictures: http://camaro69vn10.com The Website is finally Updated!
https://lateral-g.net/forums/showthread.php4?t=13756
Old 11-03-2009, 01:09 AM
trunk it! I have the Billet Specialties battery trunk tray kit.
Old 11-03-2009, 05:10 AM
almcbri's Avatar
almcbri almcbri is offline
Here is one I just picked up and it will be in the trunk.
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 11-03-2009, 01:58 PM
70rs's Avatar
70rs 70rs is offline
Trunk. There are a lot of mount systems out there. I think DSE has a complete kit with cables and everything you need.
Old 11-05-2009, 06:22 AM
J2SpeedandCustom J2SpeedandCustom is offline
It's less expensive to place the battery in the engine compartment (less O gauge wire). And it's overall lighter in the engine bay (less wire). Wiring up the charging system is easier in the engine bay. If you going to run some sort of cover you can easily hide it.
Jeff Allen
J2 Speed and Custom
Old 11-05-2009, 07:43 AM
I like the trunk. It frees up some space to mount things like catch cans, breathers, ignition, AC...etc and not clutter up your engine compartment. I used a bulkhead in my passenger tow board and it was easier to wire up misc interior systems with less wiring in the engine compartment.
Old 11-05-2009, 09:17 AM
TRUNK!
There are a couple of ways to do your wiring... going through the trunk floor... I've used bulkhead pass-throughs that I bought at a MARINE store (west marine) that tighten down on the wire and make them safe from chafe and also waterproof...
Make sure you use the proper gauge wiring... and fine strands carry more current than less strands same gauge wires.... WELDING cable works really well for this application.
