Old 09-26-2010, 05:56 PM
Default Payback on the Scales....
I've always wanted to get my car on the scales. I agreed to show my car two night for the SCCA. I got paid back with a member lending me his Longacre scales. Not a bad deal.
The first thing I did was measure the track width and length so I could find the best spots on my garage floor. Once I did that I then placed the scales and oriented the scales so they set as level as possible. I then headed to the gas station and topped off the car. I always race as close to a full tank as possible. I took all the loose belongings out of the car to simulate race trim. Next, I took the shocks down to 0 compression setting. I jounced the car on both ends and made sure it simulated my normal ride height.
She's not super model skinny at 3574 lbs. Keep in mind that's full of gas, AC, dynamat, heat wave pro, sub box, accumulator, etc. I was pleasantly surprised with the results with a big block. 52/48 with a cross weight of 49%. The biggest discrepancy is 55 extra pounds on the RR from the LR. At least half must be the battery. When I built the car, I tried to keep the weight fairly similar side to side with components. I'm not expert, but the RR isn't a bad place to have a little to much weight.
Since I clearly don't race with a remote contol in the pits, I got my fat ass in the car next. It pegged me at 199lbs. I guess I've been drinking a few to many beers lately and spending a little to much time using my new gym at the house. Anyway, the balance actually improved with a little extra rear weight. The LF did get a little heavy with an extra 72 lbs vs. the RF. The rear looks great.
When it's nice, Kelli comes with me and rides shotgun. I get a ton of ride alongs as well. She'll never disclose what she weighs so I tricked her into it. Seriously, the car really looks good on the scales with her in the car. In her defense, I think the scales are about 4-5 lbs off. I tested them before I started and it had me at 195.
I guess the moral of the story is that a good stance should mean a reasonable race set up as long as the car is built trying to maintain some type of balance. While she's up on the scales, I'm open to criticism and ideas from the racers on the site.
Old 09-26-2010, 06:21 PM
Roadbuster's Avatar
Roadbuster Roadbuster is offline
That is very cool. Are you planning to adjust anything to shift the balance? I think you have it very close right out of the box!
Jon
Jon U.
1968 GTO - SC&C's suspension
1967 911 - a few modifications
Old 09-26-2010, 06:52 PM
Track Junky's Avatar
3773 lbs with you in the car? Did you say race car? I thought you said '69 Camaro's didn't make good race cars. You got me confused.
Any how, if your looking for advise, put that thing on a diet.
Gaetano Cosentino
Old 09-26-2010, 07:12 PM
Gaetano, this is a pro touring website, it's not roadracing.com. My goal is to make the best of what I have. My point was simply that building a 69 Camaro wasn't the easiest or most econonical way to go fast. Last time I checked, I was a pretty big Camaro fan.
I'm going to concentrate on my readings with me in the car. I'll start with raising the LF a little and try to get my cross weights as close to 50 as possible. Have you scaled you car? I'm looking for advice.
Old 09-26-2010, 07:42 PM
LOL, just had to give you a hard time. Call it "Pay Back"
Anyhow, my car weights in at 3050 lbs and is 50/50 across. IMO everything boils down to weight and tires. Since you auto cross guys are stuck with 200 tread wear you are a bit challenged. Set up is everything.
If I was building an autocross car, due to the slower speeds and tighter turns I would want it to roll like Bad Penny. I imagine soft springs up front would be a benefiet, along with adjustable shocks and sway bars.
You know as well as I do, its all trial and error.
Gaetano Cosentino
Old 09-26-2010, 08:20 PM
I was going to say, I have a small fortune in this thing and use it. I think you'll be surprised how well this haas performs when I finally quit making excuses and meet you. I do plan to buy another set of rims and put a set of A6's on for autocross. I've still got the R888's I can throw on for road racing and have it dialed in pretty well in that trim. I want to get the balance right with these BFG's and then go to the A6's. I'll have all my notes and I'll adapt to the circumstances.
There is a december event at Spring Mountain in December with my SCCA. You should come over.
Old 09-26-2010, 08:55 PM
I am pretty much done for this season unless I hit the lotto. Where were you the last 5 track days I posted since May of this year.
Anyhow, my time at Buttonwillow 13CW is 2:10.125. That will give you an idea of how well your car pereforms compared to mine. I wont be heading back down to Buttonwillow unless another PT car beats my time. It's just to far of a drive.
Post your times from Spring Mountain and when I could afford to head that way I will. Be sure to let me Know which configuration you guys are running.
Are you guy's using AMB transponders?
Gaetano Cosentino
Old 09-26-2010, 10:40 PM
Cool, if I make it to Button Willow that will give me an idea of how our cars compare. You have to run RTTC 2011.
After 8 adjustments I think she's dialed. I ended up with .5 turn down LF, 1 turn up RF, and a whopping 6.75 turns up in the LR!
With me in the car I achieved 51.6/48.4 balance and a 49.9% cross weight. And I thought it was close before I started.
Me in the car:
Old 09-27-2010, 06:54 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Very cool Todd.
Not too shabby for a big block, huh?!?!
Old 09-27-2010, 07:49 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Todd...normally I would have to make a fat girl joke here, but she's a stunner. Don't worry about the weight....just how she wears it. LMAO
Curtis
