Old 01-02-2011, 12:24 PM
makoshark makoshark is offline
Default 1967 RS Camaro for sale
This is not a completed project, but well on it`s way in being one. I have a bunch of goodies for this car. Just about everything for this car is brand new or restored. I`ll give a few details of the car right now and will update more as soon as I can get some better pictures of the car.
It has NOS quarter panels replaced
New trunk lid
Original rust free GM doors
Original rust free GM fenders with patches in the bottom corners
USA made floor pans buttwelded in
Center trunk pan replaced
Rear window filler replaced
Original GM tail panel
Original GM rockers
Original roof panel
New dash top
USA made toe boards replaced buttwelded
NOS outer wheel houses replaced
USA made passenger inner wheel house and shocktower area replaced
12 bolt with GM 3.73 gear, Eaton posi, new bearings, moser axles, moser pinion yoke, aluminum diff cover
New stock gas tank
AAW full classic update wiring harness with RS front harness
GM RS headlights fully restored with new motors
All factory trim
15x7 GM ralley`s restored with BFG 235, 255 with new chrome
New deluxe door panels
All original glass
Factory tilt wheel column
Front seats, needing resto...have a few parts for them though as well as rear fold down seat
Also, 2001 Trans Am leather power seats front and rear
New SS fuel, brake lines and trans lines
76 Corvette rotors, 76 GM truck calipers, modified 69 camaro brackets front brakes...stock drums for rear...Do have an LS1 front and rear brakes
Front subframe from 68 camaro welded seams and removed upper a-arm bracket to do GMod...have original frame as well in good shape
All new tierods, HD centerlink, pitman arm, original power box
Bunch of extra odd and end stuff to go with the car as well
All new bolts
All new Hotchkis springs front and rear with Poly bushings, motor and trans mount poly too
DSE Subframe connectors, in process of installing
Smoothed firewall, in process of completing
Rough body work completed
1997 4L60E auto transmission completely built with all upgraded parts and Transgo HD2 kit, B&M trans cooler, PI Vigilante 2800 RPM stall and Spicer 1350 tailshaft, painted red with Polished aluminum pan...0 miles...all parts new
Brand new GM 4 bolt main one pc rear main 350 roller block, roller lifter spider, Edelbrock 2pc aluminum timing cover, Kevco oil pan and matching oil pickup. Melodon Z28 oil pump, All polished stainless steel ARP bolts, ARP head and main bolts, 6 3/4" SFI internal balance balancer, Eagle 4340 forged steel 3.48" stroke crank, Eagle 5.7" H-beam rods, Ross Racing Forged pistons with plasmamoly rings, polished aluminum water pump, billet aluminum accessory mounts, Prothane Poly motor and trans mounts...all items are new....Comp cams 282S cam and lifters, used, matching Comp Cams springs, new, Comp Cams 10 degree Titanium retainers, Chromoly locks and Viton seals, new...Edelbrock Performer RPM manifold, used and BG 650 double pumper, used
New TH400 trans crossmember
No hood, spoiler or inner fenders and no driveshaft
Bolero red code with black deluxe interior, added fold down rear seat
Tons of boxes of new misc. parts...too much to list
NO TRADES
$14,500 Fairly FIRM....serious inquiries only please and will provide my # to those seriously interested
