Old 08-02-2011, 09:07 PM
Twix27 Twix27 is offline
Default chevy 350 backfire
I just bought a 70 c10 and i've been trying to fix the backfiring problem. When i'm in drive it doesn't backfire but when i'm in low2 or low1 and i let off of the gas it backfires VERY bad sounds like a gunshot and its a bit embarrassing. Thanks for the help
Old 08-03-2011, 10:15 AM
70rs's Avatar
70rs 70rs is offline
Is the backfire through the carb or exhaust?
Eric
Old 08-03-2011, 07:01 PM
the exhaust
Old 08-03-2011, 08:00 PM
70rs's Avatar
My guess is a timing issue. Without knowing what cam or other stuff you have I wouldn't know where to start as a baseline. Maybe one of the guys here whos better at that could chime in?
Eric
Old 08-04-2011, 11:08 AM
its just a stock 350 with a 4 barrel holley stock heads, stock cam, everything is stock but headers
Old 08-04-2011, 03:11 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
What do you have the timing set at?
Old 08-05-2011, 04:18 PM
its at about 750 to 800
Old 08-05-2011, 07:32 PM
70rs's Avatar
That is the idle RPM. Do you have a timing light?
Eric
Old 08-07-2011, 12:06 AM
no i do not i can go rent one though what would you recommend the timing at
Old 08-07-2011, 05:20 AM
MarkM66's Avatar
10* btdc would be a good start.
