Old 03-31-2013, 06:06 AM
Anchor's Avatar
Anchor Anchor is offline
Default 67 Nova SS. Pro Touring. 398 + Twin 72's. 1000rwhp plz.
Righto, first up i'm gunna copy what's been done from another forum. Sorry about the boring **** to start with. It gets better... Sorry about the build changing directions a few times... That stuff happens. Stay with me
This build could not have happened if it weren't for mainly Jason @ Total Cost Involved. He's stayed with me for around a year now and has continued to help out exponentially without the need to! Talk about going above and beyond the job description. I really really recommend this guy/TCI if anyone is chasing hotrod or suspension parts.
Also Mike @ AES. For taking over a bit of a sour deal and turning it into a great deal!
Once the build is finished, i'll list everyone who's helped me out with what.. There's a heap! Can't thank everyone enough.
Here's a walkaround.
Yes it's an original 67 SS Coupe.
Yes i'm cutting it up and making it how i want.
"Current" plan is 1100rwhp LS1. T56. Tubular front and rear. Mod plated and legal. So far i've had my engineer with me on everything, and so far it's ok.. Also been in contact with Queensland Transport mod guys and my insurance company. I don't want to have a $$$$ build burn to the ground or get smashed up and be left with nothing.
Yeah, so err i really didn't want to do this. Wanted to buy a car and change a few small things but as always i get carried away (my last "daily" had 484rwhp and was 2" off the ground..)
My end goal is to drive this thing like i stole it. Rape it to (hopefully not) death. Originally i just planned to tidy up a few things, fix a few interior water leaks and make a little more power etc etc. Never happens the way you plan..
Here's what i started with.
Driveline:
434ci SBC. (400 stroker)
400 4 bolt block
Modified pickup
Baffled race sump
Scat crank
Forged H Beam Rods
SRP Forged Pistons
Solid Top End
Roller rockers
Decent sized cam
Kiwipro alloy heads
Alloy Radiator with Thermo Fan
Weiand Hi Flow Water Pump
Vac pump for brakes
MSD Pro Billet Dizzy
MSD 6AL & Blaster 3 coil
Edelbrock Hi Rise Manifold
Barry Grant Race Carb & Holley throttle cable bracket
K&N Filter with Extreme Top
Dual catch cans
Speed Flow fuel filter
Speed Flow fittings and braided line from tank to carb
Holley Fuel Pressure Reg
2x Holley Electric Fuel Pumps with modified tank for large pick-up
Full Manual Turbo 400
Tranny cooler
Hurst Ratchet Shifter with lockouts
12 Bolt Diff with very tight LSD. (Drags/pushes front wheels.....)
Moser Axles
4:11 Diff Gears
Battery relocated to boot
Exhaust:
Big Tube headers into twin 2.5"
Proflo mufflers
Suspension:
Fatman Fab 92 Camaro front end
Manual Rack & Pinion conversion with billet steering column
Front coilovers
Billet spacers
Adjustable strut tops
Rear heavy duty gas shocks
Reset leaves
Billet blocks
Rear springs moved in for big tyres
Front slotted rotors and rebuilt drums on rear
Wheels:
Unknown brand???? Polished lip, powdercoated center.
Front - 16x8
Rear - 17x9.5
No tubs
Stereo / Interior:
Alpine 6 stacker
Stewart Warner oil pres & water temp
Autometer Monster Tach
Billet Accelerator Pedal
New interior kit, everything...
Aftermarket Chevy Wheel
This is the list of parts in transit/sitting in my shed so far. Couldn't be bothered with pictures. You all know what this stuff looks like.
Tuet6000 T56 Transmission
TCI Pro Touring Front Clip
TCI Torque Arm Rear Clip for 12 bolt
Billet adjustable coilovers front and rear
Wilwood 4 piston 12" dynalites front and rear with black calipers
7" black dual diaphram booster
Wilwood black aluminium master cylinder
Wilwood black knob adjustment brake proportioning valve
Moser HD diff cover
Turbonetics GTK850
Turbosmart E-boost Street
Turbosmart Hypergate 45mm 7psi spring black
Turbosmart FPR1200 black
Manual Pedal Setup - 67 Nova
Central locking kit
* 67 SS Nova Coupe * AES LS & T56 * Twin Turbonetics 72mm Mid Frames * TCI Pro Touring Front & 3-link Rear *
Cuttin up original metal, cause I can....
