Old 01-19-2014, 06:13 AM
IndyNova's Avatar
IndyNova IndyNova is offline
Default Bulkhead connectors
Hey guys, finally got my 6.0 ls motor installed in the nova , and I want to split the engine harness and install a bulkhead type connector so I only have to drill one hole in my firewall to route wires through. My problem is finding what I need. Any ideas on where I can find them at? Or, if anyone has a better idea of how to achieve this, i would appreciate any advice. Thanks
Old 01-19-2014, 08:53 AM
snappytravis's Avatar
snappytravis snappytravis is offline
Default grommet
I bought a big two piece grommet from summit. I plan to drill a big hole in the center of the firewall then run my ecu wires through it. Then install the grommet.
Like this
http://www.summitracing.com/parts/SI...BL?seid=srese2
Just another idea for you, Good luck
Old 01-19-2014, 09:34 AM
Molex, Delphi, metri....they all make bulkhead type connectors that you may want. I believe that DSE sells some and possibly ring brothers...or fesler
Good luck Ryan Austin
Old 01-19-2014, 04:50 PM
Call Rodger @ Ironworks.... he uses "mil-spec" bulkhead connectors that are pretty slick.
Old 01-20-2014, 11:10 AM
ironworks's Avatar
Thanks Greg - They are on our website.
