Old 01-22-2017, 11:52 AM
jwcarguy jwcarguy is offline
Banned
Default L76 6.0L aluminum block complete engine
Item Location (City/State):Las Vegas
Price: 5700
Description:
A buddy (Curtis) has decided to go to a stroker engine for his 67' Camaro build that I am helping with
So we are listing his engine for sale, never put in car, still fresh on stand
We sourced a low mileage pullout 08' L76 6.0L from a G8 ( aluminum block 6.0L w/ "LS3" style rectangle port cylinder heads)
I broke it down and went through the complete engine
machine work was handled locally by my trusted shop Rick @ HBR Competition Engines
removed the VVT/AFM setup and
-std bore, polish crank
-new rings, main, rod & cam bearings
-Melling #10295 high pressure oil pump
-new LS2 HD timing set and damper
-new GM gaskets, seals, LS2 timing cover kit, LS3 valley cover
-LS7 lifter set w/ LS2 trays
- EPS cam 226/234 598/601 113+2 LSA cam
-Comp Cams 7.425" .080 hardened pushrods
-GM #823 rectangle port cylinder heads, milled, comp valve job, PRC .650" dual valve springs w/ titanium retainers, "LS3" rocker set w/ Comp Cams trunion upgrade kit installed
-ARP fasteners (Heads, cam, balancer, flywheel & PP)
- new LS3 intake manifold assembly w/ fuel rails,LS3/7 42# injectors & map sensor
- new LS2 "silver blade" dbw 90mm throttle body
- knock sensors, cam & crank sensors
- black powder coated valve covers w/ SS allen socket head hardware
-LS2/3/7 coil packs, harnesses & brackets, spark plug wire set
-new Corvette C6 harmonic balancer w ARP bolt
- C6 Corvette LS2/3 low profile oil pan kit w/ dipstick & tube
doesn't include front accessory drive
in Las Vegas, NV at Curtis' house
Asking $5700 obo as pictured
pm/ call/ text Jeff (702)677-4085
or Curtis (702)610-3388
