Old 03-19-2015, 09:21 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Default Big Ford End - "Bolt-On" C6/7 Hybrid Floater
C6/C7 Hybrid Floater System -
Installs onto any Rear-End that utilizes "Early" or "New Style/Torino" Big Bearing Ford Ends.
That's right,,,, you can use your current rear-end housing, NO welding & simple installation. BOLT-ON!
Advantages:
  • Bolts to your Early OR New Style/Torino Big Ford Housing End (Chevy 10/12 bolt application now available! https://lateral-g.net/forums/showthread.php4?t=52854 )
  • Reduces/eliminates brake “knockback”
  • Eliminates axle deflection
  • Wheel & tire remains intact should an axle failure occur
  • Front or Rear Caliper / E-Brake Cable Positions
  • Utilizes the robust, zero maintenance C6/C7 ZO6 Hub Bearing Unit
  • Utilizes OEM C5/C6/C7 Corvette, and 5th Gen Camaro brake kits
  • Utilizes aftermarket C5/C6/C7 Corvette, and 5th Gen Camaro brake kits
  • Utilizes your existing BAER / WILWOOD caliper & rotor (some restrictions apply)
  • Super compact design compared to traditional style full floaters
  • All advantages of a traditional style full floater without the maintenance
  • Replacement parts available at local GM dealer or local parts house
  • No modifications required to the hub bearing unit as other kits in the marketplace
Note: this applications will add 3/16″ per side to your existing wheel mount surface (based on an existing 2.50″ axle/brake offset)
Fitment: Any rear-end housings that utilizes Early or New Style/Torino Ends
Big Ford Bolt-On “Base Kit” (pictured below)
Big Ford Bolt-On “Base Kit” (pictured above)
Base Kit Includes:
• (2) Billet Steel, C-Series, Hybrid Floater Adaptors
• (2) Billet Aluminum Caliper Brackets
• (2) C7 Corvette, SKF 33 Spline Hub Assemblies
• (1) Install Kit
• (2) Hub Spacers
• (2) Billet Aluminum Hub Cap Seals
________________________________________
PRICED AT - $1,398.00
Add Axles - $400.00
• (2) Hy-Tuf Full Float Axles
Add E-Brake items - $325.00
• (2) C5/C6 Corvette Complete E-brake Assemblies
• (2) C5/C6 Corvette Parking/E-brake Cable Brackets
Have interest?
Have questions?
Need more info?
Distributor Inquires Welcome!
Below pics of the assembled "Base Kit".... (attached Big Ford End is for display purposes only)
Below pics shown with optional C5/C6 E-brake Assembly & E-brake Cable Bracket. These two e-brake items are optional and the system can be run without and added at a later date if desired.... (attached Big Ford End is for display purposes only)
Big Ford "Bolt-On" kit in action!
