Old 09-19-2007, 02:37 PM
68protouring454's Avatar
Default lokar
hey guys, what part numbers have you used to change over to lokar throttle cable? i assume you had to go with there pedal assembly so you could ditch the factory bulky linkage, please let me know what you used, or alternative that is easy to install in a finished car.
jake
Jake's Rod Shop
Old 09-19-2007, 03:46 PM
Musclerodz's Avatar
What car we talking about? They have a couple specific replacement part numbers available
Mike Redpath
Musclerodz & Customz
facebook page
Old 09-19-2007, 03:52 PM
68 camaro, hoping they have a bolt in or easy fab pedal assembly so i can use there throttle cable and get rid of the factory mess
thanks mike
jake
Jake's Rod Shop
Old 09-19-2007, 05:16 PM
Bill Howell Bill Howell is offline
Site Sponsor
Shame you didn't say something last week Jake. You rode right by Lokar when you went thru Knoxville the other day, that is where they are based.
Bill Howell
www.americanstreetcarseries.com
Old 09-19-2007, 05:48 PM
zbugger's Avatar
zbugger zbugger is offline
Jake, I've got some stuff in stock here. Sent you a PM.
Lost in a hopeless world on a path that wanders aimlessly and endlessly... As if it really even mattered.
Old 09-20-2007, 04:11 AM
70gotboost's Avatar
70gotboost 70gotboost is offline
I used the following part numbers...
throttle cable: LOK-TC-1000HT
return spring bracket: LOK-SRK-4000
I have NO problems and the throttle is smooth. On the cable itself, I removed the clevis that came with the assembly and used the ball fastened to my factory pedal.
Hope that helps,
Kevin
70gotboost
