Go Back   Lateral-g Forums > Technical Discussions > Trucks
Old 12-03-2007, 12:25 AM
race-rodz race-rodz is offline
Default gen 2 ford lightning 3 link
11111
Old 12-03-2007, 05:52 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Pretty cool, Chris.
My LS7 69 Camaro
Old 12-03-2007, 07:42 AM
syborg tt's Avatar
looks really nice -did you design the entire kit from Scratch
marty-mj
Old 12-03-2007, 11:12 AM
ccracin's Avatar
ccracin ccracin is offline
Looks good! Just one suggestion though, you may want to stiffen up the cross member you have the chassis end of the third bar mounted on. Possibly box the whole length. I have run three links for quite a while in my asphalt race cars and that bar has tremendous loads placed upon it. The stamped "U" shape used for that member is not very stiff in torsion. With th angle of the pull and the configuration of the bracket you are going to load that member in torsion. I have seen many mounting tabs pulled off and bent on 3rd bars in cars that weigh 2500 to 3000# running 2 barrel 355cu inches. Your going to be heavier with more torque. Just my 2 cents. All in all a very, very nice package. That might fit nicely into my Dad's Harley F-150.
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 12-04-2007, 06:06 AM
awr68's Avatar
awr68 awr68 is offline
Looks real good Chris!! What's that blue thing in the background?
Tony
'68 Camaro
Old 12-04-2007, 04:58 PM
awr68's Avatar
Originally Posted by race-rodz
thats a project i should have been workin on instead of this, the owner is a pretty kewl guy, very understanding
Tony
'68 Camaro
Old 12-23-2007, 06:49 AM
dave96dcm dave96dcm is offline
I really like the way that you made the pivot for the Watts link, did you have to add a crossmember near the frame mounting points to keep them from trying to seperate or pull together when cornering hard? Is that a delrin bushing on the center pivot? I need to add a Watts to my 1996 Impala SS and I really like this idea vs puting the pivot point on a crossmember.
Old 12-04-2007, 06:11 AM
ubervic ubervic is offline
Very nice work!
