Old 10-23-2007, 11:45 PM
Stem Stem is offline
Default Backspacing -70 Chevelle
Hi all.
I'm trying to get a simpel yes or no answer on this questione: I want to use the Coys C5 18x8 with 5,5" bs, will theese fit?
If not, could some one please tell me the right BackSpacing for my Velle?
I've tried to find this out my self, but there are no conversion table from inch to mm that I could find.... Please help a lost Norwegian fool here
Old 10-24-2007, 12:30 PM
7TSS's Avatar
7TSS 7TSS is offline
Are you using 18 x 8 on all 4 corners? What size tires are you planning to use also?
I would use 4.5" bs instead.
Old 10-24-2007, 04:25 PM
DriverzInc DriverzInc is offline
18x8 with a 4.75 would be better. If a 10" on the rear, 5.75-6". You should really order custom built wheels.... we can help! Call....
Old 10-24-2007, 05:45 PM
PRRC PRRC is offline
Coys only offers a 18x8 in 4.00 or 4.50 B/S. on a 70 you can run the C-5 in a 18x9.5 with a 5.00 B/S Good luck with your purchase.
Tim
www.paradise-road.com
Old 10-24-2007, 10:07 PM
Ahhhh....finally a clear answer
I'm going to use 18x8 on all four, and I think I'll run them on 265/40/18.
DriverzInc : Do you send over "the pond"? What would the prize be on a custom wheel setup?
Old 10-24-2007, 10:26 PM
Blown353 Blown353 is offline
With an 8" wheel I would go with 4" backspacing. There will still be PLENTY of room. Any more backspacing and the wheels will look very "sucked in." Regardless of backspacing 8" wheels on a 70 Chevelle are going to look small all the way around. 9.5" up front and 11" out back fit easily and fill things out much more nicely. You could also run 9.5" all the way around if you wanted.
FYI, 9-10.5" is the manufacturer's wheel width specs for a 265/40/18 tire... so it would not be recommended to put them on an 8" wheel.
1969 Chevelle
