Old 01-01-2008, 09:34 PM
youthpastor's Avatar
Default 1st gen wheel backspacing
alright guys..I know this is a DEAD HORSE and i'm beating it, but I'm getting ready to pull the trigger in the morning and get some Rushforth rates-x wheels..and I see alot of you are online and I'm tired of digging through old treads..
stock UCA's and C5 brakes, 18x8 in front
WHAT IS THE BACKSPACING??-thanks-Chris
Old 01-01-2008, 10:33 PM
awr68's Avatar
awr68 awr68 is offline
Chris I would say 5" bs but the C5 brakes may need it to be differant? It's 5" when using stock hub/discs...I guess I will learn from this too!
Tony
'68 Camaro
Old 01-02-2008, 09:47 AM
DriverzInc DriverzInc is offline
4.875" we'll gurantee it. If it's wrong, We will re-rim them for free.
Old 01-08-2008, 10:12 PM
D Rock D Rock is offline
Mine was very close to this on a stock UCA 67 and c5 brakes. I would go with this.
Old 01-09-2008, 03:02 AM
redfire69's Avatar
I didn't know 18s would fit, cool! Will they fit on the back of a non-tubbed 69?
Ron
69 Camaro Redfire
Old 01-09-2008, 04:40 AM
The diameter of the rim does not affect the fitent of the wheel (within reason). It is the diameter of the tire that determinnes that part of fitment, a 14" rim with a 26" diameter tire is the same size as a 18" wheel with a 26" tire, the later just has a lower profile, less sidewall. And of coarse you can only go so wide no matter what diameter rims you use.
18" actually fit / work very nice.
Frank Serafine
