Old 02-24-2008, 11:46 AM
marine02ss marine02ss is offline
Default $6000 to spend on Paint
Im fixing up a car for a friend of mine,its a 1968 Camaro with all new panels. Hood,roof, 1/4;s,doors, fenders,trunk, rear panel basically all new,whats the averadge price for a paint job.Can it be done for $6000.Its still needs panel alignment and all the common issues with a paint job.It also has a new floor the whole underside has been painted Boyd Red but the guy didnt do a good job,the owner wants it redone.We want the car primered first so no rust can start.Anybody out there that can chime in.Here are some pics.
Old 02-24-2008, 01:04 PM
The average price for a complete body work, panel alignment, and paint is usually $8K to $10K, or more. And that's if it doesn't need a bunch of metalwork to get the gaps right, etc. But it depends on the area of the country you're in. It is possible, but I'd say you're a little low to get a nice job done unless the guy is a friend.
By the way, that car has some nice pieces on it.
Old 02-24-2008, 01:38 PM
68protouring454's Avatar
like jody says, 8-12k gets nice paint, sanded and buffed, but the gaps are only as good as they can be without cutting and welding, etc.
6k is not alot, think about it at 60 per hr, how many hrs to strip, and prime? how many to align panels? how many just in painting time? how many in sand and buff?
you will eat up 100 hrs very very quickly, a camaro is generally 175-225 for nice body and paint, you do the math with materials, and labor
jake
Jake's Rod Shop
Old 02-24-2008, 02:15 PM
1967bigdaddy's Avatar
1967bigdaddy 1967bigdaddy is offline
That is one though looking ride. And your figure is low, as already mentioned.
So where are you from? east west north south?
Old 02-24-2008, 04:09 PM
Pricing is a bit geographical also. In the hills of Tennessee paint comes a lot cheaper behind Billy Bobs pole barn behind the house then at a shop with frontage in Cali. So where are you?
Frank Serafine
Old 02-24-2008, 04:12 PM
Im from South Texas in Laredo, Texas to be exact.Our General concern is door gaps we kinda dont know where to start, as far as mount the doors first get the gaps, then fenders and gap or vise versa. I can pretty much weld and grind, im going to shave the drip rails, capp off the door locks,weld the front fender section together etc..
Old 02-24-2008, 04:22 PM
When it comes to door gaps I always use the front leading edge of the rocker panel as a reference point. I line up the lower door edge corner to the rocker panel. I have also gotten into the habit of loading the door when doing this, because once the door is loaded, the weight causes the door to droop a little at the back. And you want a nice straight line along the lower leading edge of the door to.
Good luck and enjoy there fun to work on.
Old 03-17-2008, 08:24 PM
fesler's Avatar
fesler fesler is offline
I would say in Texas you should be able to get it done for around 8K it just depends on what your metal is like and how much is done right, 6k is not enough to do the body work you need with alignment and other things. First things firts you need to strip the car down to the metal and seal it, from there you can start all the body work and metal work.
We will not touch a car if we do not strip it and you can see some samples of why not here. http://www.feslerbuilt.com/Wallofshame.htm
Like the guys here are saying 6K will not be right and you get what you pay for so the more you pay usually if you go somewhere good the better the job is. Ask for some guys up here if they know somewhere in Texas to get a good paint job, ask around and get references to make sure you are going somewhere that does it right. You need to know
How they prep, body work, what they use, metal work and so on, check out the shop if its clean and the work looks good you are probably at a good shop. Good luck
Chris Fesler
Fesler Built - Scottsdale, AZ
