Old 03-01-2009, 07:01 PM
mwhizard's Avatar
mwhizard mwhizard is offline
Default what clutch master and line?
I've got a '71 camaro and am putting a '07 corvette ls2 with a '99 camaro t56 into it. Question is, what clutch master should I use? I didn't get the matching master for the t56 and have just realized that GM uses some rediculous quick disconnect hydraulic fitting that no-one else seems to make.
Any of you guys out there run into this issue? What did you do? Help?!?
