Old 03-10-2009, 01:11 PM
Mikael A Mikael A is offline
Default Were can I find a tool to make
Were can I find a tool to make these holes.
Mike a
Old 03-10-2009, 01:24 PM
Swain's Avatar
Swain Swain is offline
Google Dimple Die Tool
Old 03-10-2009, 01:44 PM
deuce_454's Avatar
i have seen one made on a lathe... two turned pieces with a hole thru both for a long bolt, in one end of the two there was a male and female "punch" to cut/stamp the hole.. (and a valve spring in the female to pust out the stamped out piece) turn them both 180 deg and re-insert the bolt and they would fit together to form the edges of the hole.... could be worked with either a wrench or pneumatic/electric impact wherch....
google time found this:
http://www.mittlerbros.com/punch__flares.htm
Jake: Hit it.
Old 03-10-2009, 01:54 PM
tjbruning tjbruning is offline
www.trick-tools.com
Old 03-10-2009, 02:27 PM
Thanks,I have a press and a lathe so I will make my own.
Mike a
Old 03-10-2009, 09:22 PM
bentfab's Avatar
bentfab bentfab is offline
Mitler Brothers
Follow us on Instagram = @bentcustom
www.bentcustomandperformance.com
