Old 08-23-2009, 05:07 PM
The T-man The T-man is offline
Default 17" or 18"?
trying to decide between 17" or 18"
I am mainly concerned with fitting the widest tire/rim combo possible uner the car
1973 Camaro
thoughts and/or pics?
Old 08-23-2009, 07:06 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
18's!
Chris
Old 08-23-2009, 07:10 PM
I have a 72 and went with 18's
Old 08-23-2009, 08:16 PM
JayR JayR is offline
Lateral-G Supporting Vendor
Here's one we did with 19s all the way around in stock wheelwells as an example of diameter not affecting fitment.
Along with this one running 18s all the way around.
Old 08-23-2009, 09:41 PM
turbo67camaro turbo67camaro is offline
Given your main concern of using the widest rim and tire you can, then 17" should make that easier than a taller rim of 18", given a tire of the same height.
Old 08-26-2009, 01:20 PM
anyone else?
Old 08-26-2009, 01:43 PM
Apogee Apogee is offline
I think Jay's pics say it all...definitely 18's. More room for brakes as well which is never a bad thing. Assuming similar tire heights, wheel diameter doesn't really play a role in determining your max width for fitment purposes as the outside profile of the tire remains the same.
Tobin
KORE3
www.kore3.com
Old 08-26-2009, 02:19 PM
skatinjay27's Avatar
jason, you got anymore pics of that silver one?
that thing look bad azz!
AJ
Old 08-26-2009, 07:06 PM
Thanks Man! Double compliment because he's a design client and a wheel client.
And just in case your decision hasn't been hard enough, here's one we did with 18s and 19s
Old 08-26-2009, 09:37 PM
Cread01 Cread01 is offline
Those cars look sick... You deffinately make some of the best looking wheels out there. I'm saving my pennies as we speak... hopefully some day.
