Old 11-25-2009, 10:10 PM
jcal87's Avatar
jcal87 jcal87 is offline
Default 115v 20 amp welder question?
Does a 115v 20amp welder need a special plug in a house or will a standard garage plug work? Is this sufficent enough to do sheet metal work on a car?
1968 Camaro Blue
1968 Camaro SS (Sold)
Texas A&M Alumni
Old 11-26-2009, 07:05 AM
68protouring454's Avatar
yes its a reg 3 prong 115v plug. you want to make sure its a 20 amp circuit, both the breaker and it being #12 wire to the outlet, its best to use an outlet with nothing else running off it.
yes it will weld anything you need ot weld on a camaro
Jake's Rod Shop
Old 11-26-2009, 08:20 AM
I am a huge fan of this welder
http://www.hobartwelders.com/product...ed/handler140/
I got mine on Ebay new for 400.. you can also get them at tractor supply.
I have 110 three prong 20 amp circuit (mine are still the old glass fuses)
Never had a problem with blowing the circuit. It easliy welds sheet metal and steel tube. (made a body cart not problem)
Old 11-26-2009, 09:54 AM
jcal87's Avatar
Awesome thanx guys!
1968 Camaro Blue
Texas A&M Alumni
Old 11-26-2009, 05:35 PM
E.rodz's Avatar
E.rodz E.rodz is offline
welder will be fine for what you need it for.but the power will drop off like a rock if you plug an extension cord into it so make shure the 20 amp outlet is close to where you need it.if you need an extension cord use a short as possible and a big cord.
my name is Eric Hokenson I have a dream of building ten of the coolest hot rods out of my home shop wish me luck I am going to need it! - more pics on my web site www.erodzcustoms.com this is just for fun and i am NOT looking for any more work!
Thank you supporting sponsors! without you guys there is no way I could do this myself !
Modern automotive performance,Ring bros.,Yank convertors,extreme drive systems,Cj tunes,race coatings stainless works,Modern Automotive Performance.all of these shops have the experience to get your car to the top.
Old 11-26-2009, 05:46 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Originally Posted by jcal87 View Post
Awesome thanx guys!
Where are you at with your project? It's been a while since we last talked.
Chris
Old 11-26-2009, 06:43 PM
jcal87's Avatar
Dead stand still right now I'm hoping to get it rolling this month. Hey i was going to ask you what are you using to cut all of your tubing for carts and bracing etc.? because I thought about just getting a hand grinder and cut off wheel I have to be careful what I do and what I use due to the fact I live in a rental house.
1968 Camaro Blue
Texas A&M Alumni
Old 11-26-2009, 08:58 PM
Lots of us use abrasive wheel 'chop' saws - but that wouldn't work for you unless you can setup outside and off the driveway. They throw off tons of sparks, smoke like hell, really noisy and stink up a garage quick. I've also had friends use them in the driveway - and when the grindings get wet - they rust and stain the mad owners purdy driveway....
http://www.harborfreight.com/cpi/cta...emnumber=44829
I use a cheap Harbor Freight band saw for the basic cutting jobs:
http://www.harborfreight.com/cpi/cta...emnumber=93762
A bit slow - but if you use quality blades the final results are good IMO.
Jim
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 11-27-2009, 06:54 PM
ItDoRun's Avatar
I used our saw at work, but for all my bracing a sawzall should work fine. Or as suggested, a band saw.
Chris
Old 11-27-2009, 08:57 PM
jcal87's Avatar
Yeah i think thats what i am going to go with do you have yours hooked up to a bottle? and what size wire do you use?
1968 Camaro Blue
Texas A&M Alumni
