Old 11-21-2009, 04:41 AM
FIREFIGHTER273 FIREFIGHTER273 is offline
Default 2nd Gen?
Hello folks I am new to this site and would like to say its awsome! My question is "What would be the best way to lower a 2nd gen Trans Am up front?" could I go with springs, or should I go with spindles? I am not building a radical ride, but I would like to see it a lil lower. The car has the 17" snowflakes all around with the 403 motor. I am sure the may be a rookie question for most of you guys, but I wanna do it once. Thanks alot folks.
Old 11-21-2009, 08:04 AM
66LS7's Avatar
66LS7 66LS7 is offline
Default Heidts
Welcome to the site, you will find everyone here is always willing to help solve problems. I own a business called D&Z Customs LLC. & have been working with the guys at Heidts Hot Rod & Muscle Cars on our project "Re-Peeled" which is a 70 Camaro. Heidts has a great 2" drop spindle that would be a great product to use on your car. I am set up as a dealer give me a call or e-mail & I can get you set up.
Thank You
Randy(D&Z Customs LLC.)
[email protected]
1-262-347-9741
Old 11-21-2009, 04:43 PM
tony byram's Avatar
tony byram tony byram is offline
Hi! And welcome!
lots of great cars and ideas plus advice! Im running QA-1 adjustable coil-overs I got from Jegs. They work great on my 72 Z28 and also improved the handling!
Old 11-22-2009, 10:01 AM
pro-tour79's Avatar
pro-tour79 pro-tour79 is offline
Supporting Vendor
Wellcome to the board, answer your question, when lowering a vehicle you MUST increase the spring rate to avoid bottoming out, second you will improve the ride and the handling, third it's the most economical/ functional way to lower your car, forth you old springs probably need changing any way.
On the subject of droped spindles, IMHO/facts, one of the worst things done to practical vehicles, the problems: limits back spacing options on wheels (big problems for Camaros), increases scrub radius, lowers the car without increasing spring rate causing bottoming out.
unless things have changed heidts only has one spindle, to fit 1st gens, 2nd gens, A-bodies how does that work!!!!???? for starters, ball joint tapers are not the same, outer wheel bearing are not all the same, bolt on steering arms, how many are available? do they correct bump steer on 3 different front geometries, do they allow for more back spacing, IIRC they are not even as tall as the stock 2nd gen spindles so it would affect the geometry in a negative way, not to mention special brakes.
www.pro-touringf-body.com
Old 11-22-2009, 03:43 PM
NOT A TA's Avatar
NOT A TA NOT A TA is offline
Welcome!
John Paige
lab-14.com
Old 11-24-2009, 12:22 PM
Hotchkis Hotchkis is offline
senior member
Using lowering spindles does not change any of the handling characteristics of the vehicle, they merely lower the car by the said amount, and they can cause turning radius issues if you go too extreme. The advantage to springs is they allow the tuner (manufacturer) to pick spring rates that better control the available suspension travel as well as increase the rate to give the vehicle a firmer feel and better handling. So with springs, you get improved stance and better drivability.
Old 11-30-2009, 06:45 AM
Heidts#14 Heidts#14 is offline
We do not offer 2" drop spindles for the 2nd gens
