Old 07-16-2010, 02:56 PM
Joejaze's Avatar
Joejaze Joejaze is offline
Default Wayne Due C4 Sway Bar Question
I have a Wayne Due C4 front clip for a 69 Camaro. Unfortunately it did not come with a sway bar. I was wondering if anyone happened to know if a stock 69 Camaro bar would work and what end links should be used? Any information you can provide is appreciated.
Old 07-16-2010, 03:09 PM
coolwelder62's Avatar
From the photo's I have seen I don't think so.I would retro fit a speedway engineering splined bar & arms. Should be able to find some photo's from the mule build for idea's.Good luck.
Old 07-16-2010, 03:19 PM
Joejaze's Avatar
Thanks.
A universal sway bar is the plan if I cant get a good enough answer on a stock unit. Hopefully someone with this front clip in their car can chime in...
Old 07-16-2010, 04:30 PM
I think that's a stock First Gen bar on this one............
Old 07-17-2010, 06:03 AM
Joejaze's Avatar
Nice! Thanks Jody!
It looks like there is a bracket made up for the end links that fits into the lower control arm. Thats the only thing I will need to figure out.
Old 07-17-2010, 11:35 AM
Z06vette's Avatar
Z06vette Z06vette is offline
I have a WD C4 subframe w/sway bar. If you need any pics or measurements, let me know.
