Old 08-08-2010, 07:18 PM
aany001's Avatar
aany001 aany001 is offline
Default will this pan work??
Guys I was wondering will a LS Hummer oil pan have enough clearance for my LS1 swap in my 69 camaro with a stock frame and with a unisteer rack??
Old 08-08-2010, 07:27 PM
SLO 65 SLO 65 is offline
There's a good "sticky" on LS1 Tech in the Hybrid/Conversion section that has all of the dimensions for the different LSx pans. The Hummer pan is 7.5" deep vs. 5" for the F-body and LS2/3 Corvette pans. I don't know if either will clear the rack.
Nick
Old 08-08-2010, 07:40 PM
They are dangously deep and serious threat of high centering
Frank Serafine
Old 08-08-2010, 07:43 PM
aany001's Avatar
just went to the garage and compared the measurements to my 96 chevy small block's oil pan that was in the car with the rack and the measurements are almost identical.Looks like it will fit perfectly without any mods.Heres hoping and will let you know this sat when my new drivetrain arrives.Anyone knows if the dimensions of a conventional chevy small block are similar to the LS1 as in where they sit in the frame??? If they are close this will work.I had tons of room with my old engine in there!!!
Old 08-08-2010, 07:44 PM
aany001's Avatar
Sorry Frank what do you mean? Are you meaning ground clearance will be an issue??
Old 08-08-2010, 07:47 PM
aany001's Avatar
I was talking about the 2008 H3 Hummer pan.
Old 08-13-2010, 05:07 PM
aany001's Avatar
anyone else run this pan and worked for them?
Old 08-13-2010, 05:47 PM
Yes, that pan will hang over a inch lower the the engine crossmember which is a disaster looking for a place to happen
Frank Serafine
Old 08-13-2010, 06:21 PM
dhutton dhutton is offline
http://www.pro-touring.com/forum/sho...hlight=brp+pan
I think that is just about one of the worst pans you can use in a first gen.
Old 08-13-2010, 08:41 PM
aany001's Avatar
Ah man I installed the engine and ya it sits way too low for me.Also the pan hits the crossmember and wont allow one of the engine mount thriugh bolts to line up.Back to the drawing board..........
Thanks for all the input guys and anyone know of the best pan to use on a tight budget?? I have access to a buddy that has tons of different LS series pans and a fabricator to message them as required.
