Old 11-22-2011, 03:30 PM
orangevert's Avatar
orangevert orangevert is offline
Default Picking up a LS7 tonight...
Im going to pick up a 07 LS7 block tonight from the machine shop, Now the engine researching begins, 500-600 hp is what Im aiming for, I'll be happy with 475 RWHP... I say that but Id rather over build it then under build.
If anyone has any spare LS7 parts laying around please let me know.
Thanks Kirk
Kirk
67 Convertible LS7 BBC 542HP.540 TQ
400 Turbo, 12 bolt posi, 13"12'' CPP Disc, Hotchkis connectors, belly pan.. Hush matt. 3" mandrel bent and load of other stuff.. More a show an Go..
Old 11-22-2011, 04:21 PM
Devil Dog's Avatar
Devil Dog Devil Dog is offline
Default Ls7
Sounds exciting!
Good luck with the build
Semper Fi
Old 11-22-2011, 05:10 PM
XcYZ's Avatar
XcYZ XcYZ is offline
You goals will be easy with that motor.
My LS7 69 Camaro
Old 11-22-2011, 06:07 PM
MaxHarvard's Avatar
The oil pan might be a challenge if your putting it in a first gen.
Old 11-29-2011, 07:36 PM
daytonayellaz daytonayellaz is offline
Will it be using the dry sump system? You could always buy a LS3 stroker crank to keep the cubes at 427 and then it would have the shorter crank snout. Then the motor can be ran in wet sump form. Then pan options are opened up.
Old 11-30-2011, 06:03 AM
orangevert's Avatar
Daytonayellz..... Thanks, Im new to the LS stuff so if there is a forum or book that you can point me to. I've been hanging out at LS1 Tech looking for parts
This is the info Im looking for. I want to run a wet sump. When I bought the motor, I got 799 heads, a crank from a 6.0. rods pistons, water pump, timming cover,
How much of this can I use?
Kirk
Kirk
