Old 04-17-2012, 06:40 PM
aany001's Avatar
aany001 aany001 is offline
Default DSE cross brace what height should it be?
Having trouble with my rear shocks having enough travel in my 69 camaro with DSEs mini tub kit with 3" drop leafs. My question is how far up should the cross brace be in the trunk? Can anyone measure their car and please get me some direction.When my shock is installed (DSEs mini tub Koni shocks) I have 0.75" before the shock hits the bump stop and I still wanna lower the car alittle more! Please help!!!
Old 04-17-2012, 06:51 PM
Musclerodz's Avatar
1.5" above trunk floor.
Mike Redpath
Musclerodz & Customz
facebook page
Old 04-17-2012, 07:08 PM
aany001's Avatar
all the way across?
Old 04-17-2012, 07:42 PM
Musclerodz's Avatar
Originally Posted by aany001 View Post
all the way across?
yes. the minitub kit do not give clear instructions on install, but the quadralink instructions do and installs the same with exception to shock position
Mike Redpath
facebook page
Old 04-17-2012, 08:09 PM
Rick D's Avatar
Rick D Rick D is offline
Mike, can the crossmember for the leafs and the q-link be installed to be used with either setup? Going with leafs now but if I want to switch to q-link later could the crossmember be installed for both? I taked with DSE and they thought it may be possible but they had not done it.
Rick
Old 04-17-2012, 08:17 PM
aany001's Avatar
really confused cause I spoke with DSE today and they say I should have 5 to 6" of crossmember showing?? When looking in from the trunk! I have 1.5" at the lowest point and up to 3" cause the floor is not level all the way across. Also just not happy with the shock being 90% compressed at ride height! Should I raise the shock mount up about 2"???
Old 04-17-2012, 10:02 PM
Musclerodz's Avatar
No because the 68-69 is stagger shock and crossmember mounted at an angle. Quadralink is mounted striaght across. If you already have it installed, i would consider modifying the box rather than trying to completely redo it which would not be fun.
Mike Redpath
facebook page
