Old 08-01-2012, 07:20 AM
boostin05blacks boostin05blacks is offline
Default Ls front assessories not in line?
Ok guy/gals. Ive run into a problem that I can't seem fix. I've talked to some people in the industry and no one has any solid answers. Btw thanks for your time Travis! I bought a gm crate lsx454 straight for gm. Come with the harmonic balancer already installed. I then found a full used setup and bought it all (was told it had very low miles). That whole set up came with a harmonic balancer but I decided to run the one that came with the motor. So when I brought the car to the tuner for the first time and he was trying to do the crank relearn (revs the motor up to 4k) he says it threw the belt due to it not being in line. That the crank is sunk in 1/4". So I get the car back and take look..now I come to the conclusion it was one of two things. Either the crank is in too far causing it to throw the belt or when the motor torqued the belt touched the upper control arm on the drivers side and caused it to throw it.(which I plan to file down some more- has about 1/2-3/4" of clearance ATM.)
So being that I had the other harmonic balancer I decided to change it to the one that came with the assessories. Changed it out and here's a comparison.
One that came with the lsx454 motor on the left and one the left the one that I bought as a kit used.
So I swapped them out and figured the problem was solved. Go to start the car this past saturday and I can hear a repeatedly slapping. Go to the front of the motor to see the passenger tensioner slapping repeatedly and the belt going in and coming off the harmonic balancer is almost ribbing in a way like its trying to walk off but is not. But it does not throw the belt. On Sunday I start the car again.. This time no slapping of any kind and seems to be on just fine.. Started the car again later on Sunday same thing..totally fine. I'm lost on what to do..aside front buy a whole new front end setup. The only thing I can think now is to shave the mounting bracket that houses the alternator, power steering pump and drivers tensioner. I'm thinking shaving the back side a 1/4 " will help the problem...any one have any suggestions or input it would be greatly appreciated. Thanks Steven
One with the old harmonic balancer:
Old 08-01-2012, 01:36 PM
hifi875's Avatar
hifi875 hifi875 is offline
I believe correct me if i am wrong, but you have to match the balancer with the accy system. a corvette system like your would require a vette balancer, like wise a truck accy system uses a truck balancer. camaro(4th gen) and so on. I know i had to use a vette one on my setup
Old 08-01-2012, 04:08 PM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
Very true. Found this site awhile back with some good swap info on it. Not sure why the picture doesn't work (not for me anyway) showing the balancers all next to each other: here
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 08-01-2012, 04:39 PM
aray327's Avatar
aray327 aray327 is offline
take a straight edge (like a long level or metal yard stick) and lay it across the balancer and across your accessories. It will visually show you if they are all inline with each other.
one day my ride WILL be as nice as yours...
Old 08-01-2012, 05:10 PM
parsonsj parsonsj is offline
Steven, those two dampers look the same to me. I don't see why swapping them would make any difference at all.
John Parsons
Old 08-01-2012, 05:55 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
x2. Is the belt the right length and not worn?
